D16 Driver Side Coolant Leak
Old 09-25-2010, 10:06 AM
Chads7's Avatar
Icon2 D16 Driver Side Coolant Leak
Ive used search and google...nothing
Water Pump?
Went to get gas late the other night, about a half mile there and back from my house. When I got back to the house i forgot my headlights on and I noticed steam coming from under the hood(and the smell of maple syrup ). The coolant temperature never spike so i pulled it in the garage and jacked it up. And when i popped the hood the first thing i hear from a friend is "Your alternator is leaking?" Coolant was leaking on top of the oil pan. I let the car cool down over night and filled the radiator (still on jacks). Now a steady stream of coolant is leaking on top the oil pan.
First thought water pump?
Checked oil, its not milky.
I recently changed Thermostat, Thermostat Housing, and Radiator was changed by PO.
ANY HELP?
Old 09-25-2010, 10:20 AM
fv8s's Avatar
Default Re: D16 Driver Side Coolant Leak
did you RTV your thermostat housing? there is a good chance its dropping from the t- stat housing down onto your pan. just go over everything and look to see where the leak is coming from its not hard?
Old 09-25-2010, 10:22 AM
fv8s's Avatar
edit: not sure if coolant would travel from the passenger side t- stat housing all the way across the pan to your drivers side. did you check the back of the engine where the block meets the head to make sure it is not coming out of there or the intake manifold?
Old 09-25-2010, 10:24 AM
Chads7's Avatar
i used "hondabond"
Ive checked the housing its dry, not leaking at all :/
Old 09-25-2010, 10:31 AM
fv8s's Avatar
ok well move across the engine checking where its dropping from. your obviously not leaking coolant from the pan so move up. and the burning is most likely the coolant dropping on the exhaust manifold or just getting hot from the engine heat and burning
Old 09-25-2010, 10:34 AM
Chads7's Avatar
haha
I know its not the oil pan its just got me stumped that its doing it while the car is off
Old 09-25-2010, 10:40 AM
fv8s's Avatar
well like i said its most likely dropping from a higher point. use those two things on your face called eyes to look and see where its coming from. the coolant isn't going to jump up and slap you in the face telling you where its leaking from
Old 09-25-2010, 11:06 AM
Former User's Avatar
Water pump
Old 09-25-2010, 11:08 AM
fv8s's Avatar
Originally Posted by RonJ@HT
Water pump
good call... except he will have to pull the timing cover off to get a good view
Old 09-25-2010, 11:13 AM
Chads7's Avatar
Using a dental mirror i may have found the leak, it appears to be dripping from the weep hole. So water pump it is.
And thanks, I forgot those were up there.
Old 09-25-2010, 11:22 AM
Chads7's Avatar
Water pump
Thank You
That was the type of reply i was looking for, not insolence.
justseeingifitistaken
01-10-2007 08:26 AM
dc2long
06-16-2006 11:26 AM
sdr KEL
05-04-2006 02:25 PM
SPORT INJECTION
08-25-2003 12:15 PM
tylermaxon
02-13-2003 04:00 AM
Quick Reply: D16 Driver Side Coolant Leak
