d15b7 swap to d16z6
d15b7 swap to d16z6
im gonna swap to a d16z6 but i am wondering if i could just use the original transmission with the d16z6 one other thing is im gonna swap to manual if i have the transmission and everything for the transmission what else do i really need? yes and i understand how silly these questions sound im just confirming so i dont waste a buncha money
Re: d15b7 swap to d16z6 (dippy)
yes your d series transmission will bolt on to your d series engine and as far as the auto to manual
guide
https://honda-tech.com/zerothread?id=2090074
parts
https://honda-tech.com/zerothread?id=1316692
good luck
guide
parts
good luck
Re: (92shade)
Cool, well if ur going to swap from Auto to Manual then you are going to have to buy a new transmission mount for the top of the tranny, you can buy the conversion mount to bolt up perfectly, or you can cut and weld the side bracket from a manual on it, me personally I would do the Tranny mount, it'll be easier and you'll know it works correctly..
And your auto tranny will bolt up to ur z6.
yeah, your trans will work. i actully just did the same swap yesterday, (D15B7 to D16Z6) ext. i all ready had a manual. good luck with ur swap & conversion, it'll be worth it.
Re: (1phatEG8)
I hear that their is a lot of racing going on up there on the weekends, and I was kinda tired of going to kennesaw for some action here.. just going to see how things were up there, it's about an hr from me.
Re: (iamthefollower)
I haven't heard much about it, most of the people here just go to Bristol Speedway on the weekends, it's the same track they run NHRA on so it's pretty nice. but if thats only a hour from you, then id try it at least once.
yeah you will be able to use the existing harness with your z6. the only wiring you will need to do is run your vtec wiring for the solenoid. theres 2 or 3 i kinda forgot right now, but if you have a question pm me, i'll be able to direct you to the exact info you'll need.
cool thats the exact same swap i'm planning on doing this summer. only difference is i have a manual tranny already. should be a nice and easy swap for my first time i think.
it was a d15b and swaped it to a d16z6 singlecam vtec changed the ecu
to a vtec ecu
its runing out in the street winning money
yes theres a diffrence in the ecu's u can look it up in faq's.. if u want to make it a manual..or u can juz get a manual one ....u can still use it if thats what ur askin ....
im wonderin if i asked this before but i cant seem to remember the answer mite have been on another thread but for auto to manual conversion on a del sol can i use a civics shift linkage on the del sol?
