d15b7 misfire?
Old 03-18-2005, 05:43 AM
JimmyAtlantis's Avatar
Default d15b7 misfire?
When I fire it up, especially on the colder mornings, she'll idle at 1500rpms. About every 10 seconds or so the engine will *POP* and the idle will drop 200rpms and go right back up to 1500. It'll do that until I start driving, then everything's fine. Plugs have ~1000 miles, wires ~12,000 miles and cap and rotor ~8000 miles. Let's hear some theories and how to go about fixing this. TYIA
Old 03-18-2005, 06:15 AM
IHateJDM's Avatar
Default Re: d15b7 misfire? (JimmyAtlantis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">When I fire it up, especially on the colder mornings, she'll idle at 1500rpms. About every 10 seconds or so the engine will *POP* and the idle will drop 200rpms and go right back up to 1500. It'll do that until I start driving, then everything's fine. Plugs have ~1000 miles, wires ~12,000 miles and cap and rotor ~8000 miles. Let's hear some theories and how to go about fixing this. TYIA</TD></TR></TABLE>
How many miles does the motor have? That kind of stuff happens to honda motors all the time. When the motor is cold, fuel doesn't dissipate into the air as quickly, and the cylinder doesn't fire. My car is hell to drive on a cold morning until it warms up. I wouldn't worry about it unless the engine actually dies when it misfires.
Old 03-18-2005, 08:12 AM
Default Re: d15b7 misfire? (93delslo)
The engine has 152,500 miles. Honda engines may do this, but I want to fix it. Anyone else have any help?
Old 03-18-2005, 08:14 AM
IHateJDM's Avatar
its not a big deal at all, but the first thing I would check is that you have the correct gap for all your spark plugs.
Old 03-18-2005, 09:04 AM
Bump for some more opinions. C'mon guys...this is REAL tech.
Old 03-18-2005, 10:20 AM
WTF? I haven't been in here in a while, but has this turned into the forum of stolen cars, HIDs and hood locks? ClubSI?
Old 03-18-2005, 11:48 AM
So nobody knows **** about d15b7s? Is it not JDM enough for help?
Old 03-18-2005, 12:19 PM
Testing 1, 2...1, 2. Is this thing on?
Old 03-18-2005, 01:07 PM
clint g's Avatar
when my d15b7 started doing that i lost compression shortly after so get a compression check and also check for any block wear good luck
Old 03-18-2005, 01:28 PM
Default Re: d15b7 misfire? (clint g)
What exactly has to be done to regain compression?
Old 03-18-2005, 01:33 PM
IHateJDM's Avatar
piston rings, gotta take apart the block
Old 03-18-2005, 02:00 PM
I'd probably be best off just doing a complete rebuild or finding a new engine, huh?
waymay1305
Acura TL, RL & ZDX
07-05-2008 12:56 PM
dth0ng69
06-28-2008 08:04 PM
Takymoto
02-18-2007 11:33 AM
epoch707
03-17-2006 03:11 PM
Xxcivic99xX
08-10-2004 05:59 PM
Quick Reply: d15b7 misfire?
