d15b oil pump seal / crank seal / front main seal
Old 02-21-2006, 02:03 PM
ham
ham's Avatar
Default d15b oil pump seal / crank seal / front main seal
whatever its called!
anyways i have a leak just under my crank pulley, pan seal seems to be fine.
i got this pic from another thread, unsure if its d series or not but can the seal be changed without removing the pan or oil pump??
Old 02-21-2006, 08:38 PM
ham
ham's Avatar
Default Re: d15b oil pump seal / crank seal / front main seal (ham)
i think im gonna give it a shot
Old 02-22-2006, 12:07 AM
allen7-civic's Avatar
you can't you have to take the pan off
Old 02-22-2006, 12:21 AM
Tad
Tad's Avatar
well i've done the other side(flywheel side) without removing anything.
just drilled alil hole in the seal, then used a bent piece of metal to fish the thing outta there. And tapped the new one in with a piece of wood.
but i dont think that's doable with that crank sticking out like that on the side ur trying to do...
just pull the oil pump
Old 02-22-2006, 03:24 AM
ham
ham's Avatar
Default Re: d15b oil pump seal / crank seal / front main seal (allen7-civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allen7-civic &raquo;</TD></TR><TR><TD CLASS="quote">you can't you have to take the pan off </TD></TR></TABLE>
why?
Old 02-22-2006, 05:23 AM
92civeg's Avatar
i had the same leak and it turned out to be my cam seal....i would pull your valve cover and check it first
https://honda-tech.com/zerothread?id=1505552
Old 02-22-2006, 05:45 AM
das
das's Avatar
I had to drop the pan to remove the right side cover to get the real seal out ( it was baked in place ). Last night was up till 3am reinstalling the new flywheel/clutch. If I can stay awake , I will pull apart the front (left side) of the engine to find the leak on that side.
To get to the left seal on the oil pump, you have to do most of the steps to change your timing belt. That also involves taking the valve cover off.
This would be a good time to check/ and/or change the belts while it's all apart -fer sure!
The oil pump seal appears to be an o-ring (chapter 8 pg 3 of my service manual ) and liquid gasket.
das
d15b8 in my 93 cx
Old 02-22-2006, 06:40 AM
JDMCivicEF9's Avatar
Default Re: d15b oil pump seal / crank seal / front main seal (das)
I agree with Tad. You can do it the way he did or get a pick hook, it worked for me. Removing the the oil pump also works.
Old 02-22-2006, 07:53 AM
ham
ham's Avatar
Default Re: d15b oil pump seal / crank seal / front main seal (JDMCivicEF9)
thanks guys. i forgot to mention this is a brand new jdm d15b, well it looks brand new but it has some mileage.
i was assuming the first dry start ruined the front main. ill just get the valve cover and timing belt off and everything and check it all out.
jonny11844
10-15-2013 01:11 PM
mattbatson
03-30-2009 07:23 PM
mahatma
08-25-2006 08:15 PM
92civeg
02-26-2006 09:47 PM
NSTY Z33
08-04-2004 10:55 PM
Quick Reply: d15b oil pump seal / crank seal / front main seal
