d series with high compression
hello honda tech i have a few questions before my sohc build. first question what it]s the best d series engine fore high compression d16y8 or d15b or d16z6? an second question if i do high compression pistons should i get new rods? an should i mill an port the head before put new valves retainers an springs in?
Re: d series with high compression
To directly answer your question, the A6 and Z6 are the best D series motors.
That said, if you're asking these questions, you probably shouldn't be playing with these things. Pistons, rods, sleeves, and those are just the basic things you'll need to get any real power. By the time you're done getting everything, I could have used the money you spent on just your engine to buy a Civic, boost it, and be faster than what you've put together.
If you get High Compression Pistons you could use your stock rods (you should be fine with the stock rods but check for warp-age).
You can mill the head before you put the valve-train in or you can put the valve-train first then send it for milling.
If you are going to port the head then you need to give your machine shop the valves so they can port-match it to the new valves you are going to use.
Ferio Wdm Edition
Everyone is right, i thought the d was almighty...then i felt gsr vtec...saving money to swap. D series just isnt worth it unless you're bisi
shortdahri
03-25-2002 08:49 PM
