D series GURU'S step up! p1399
I have a 2000 honda civic ex 1.6l vtec, 162,xxx miles with a misfiring problem.
car runs like ****, except for at idle.
throws codes p1399 (random misfire) and misfire codes for cylinders 1, 2 and 4.
Thought for sure it was the dizzy
replaced dizzy, cap, rotor, and plugs.... didn't change a damn thing
My buddy (an acura tech) helped me do a valve adjustment.
didn't change a damn thing.
checked the timing..DEAD ON
did a compression check... compression read low so we concluded head gasket as the motor has had an over heating problem in the past.
tore the head off... head gasket looked fine... took the head to a machine shop and it was straight as can be.
Valves are all tight and hold water.
The cylinder walls were glazed so we figured the piston rings are so worn that they were causing low compression and misfires.
Did a quick hone job and replaced the rod bearings and piston rings, cleaned the carbon off the pistons and slapped everything back together, reset the timing and...
we changed the map sensor, fuel filter, tps sensor, and even tried another new dizzy.
nothing! car runs fine at idle, timing is straight, when you hit the gas the car runs rich as hell, like the timing is off and the gas is being blown right out of the exhaust before ignition.
we are left to believe its the ecu or crank position sensor....
anyone have a similar problem??
Re: D series GURU'S step up! p1399
I will also add the car doesn't rev past 3000.... not because its in limp mode jus because the timing is so far off.
which leads me to believe ecu or crank position sensor.
i know this doesn't help you solve the problem...
..but did you really rebuild a motor and put several hundred dollars in parts into it to get rid of a missfire code instead of buying a Honda factory service manual and finding a diagnostic flow chart for code P1399?
i'll try to get some info for you this evening if i get a chance.
dizzy bought and returned=$0
valve adjustment=free
buddys spare parts sensor checks=free
fuel filter 8 bucks
headgasket 40
rod bearings 30
pistons rings 35
pizza and beer 50
the rod bearings looked like ****, the cylinder walls were glazed, and the pistons had signs of blow by.
for about $150 bucks we got a **** load done. Too bad we still haven't fixed the damn problem.
which is what this thread is about.
fuel filter 8 bucks
headgasket 40
rod bearings 30
pistons rings 35
pizza and beer 50
alright well you have basically rebuilt the whole motor now XD
I would say its the ECU. I had a similar problem on my car. If its running rich as hell, have you checked the reading from the map sensor? In my car one of the wires on my harness that provides power to the map sensor was partially broken and the map sensor was reading 10PSI of boost 24/7, and the TPS thought that you were @ 50% throttle all the time. It was pretty bad, i got it to run fine at idle but as soon as i stepped on it it would start to flood out.
have you done a leak down test on the engine? maybe a faulty injector? when you say it wont rev past 3000 rpms, is it because its breaking up/ sputtering?
fuel filter 8 bucks
headgasket 40
rod bearings 30
pistons rings 35
pizza and beer 50
fuel filter 8 bucks
headgasket 40
rod bearings 30
pistons rings 35
pizza and beer 50
i'll relay the list from the factory service manual relating to random misfire-
possible cause
-fuel pump insufficient pressure, or flow
-clogged fuel line
-clogged fuel filter
-fuel pressure regulator stuck open
-[EGR malfunction] Y5 only
-distributor malfunction
-ignition coil wire open, leakage
-ICM malfunction
-MAP sensor range/performance, poor responce ('96 models)
-carbon deposits on valves
-low compression
-IAC malfunction
-VTEC system malfunction
-O2 sensor circuit
since you've basically replaced the entire ignition system already, i would start with the fuel system. check the pressure, should be 46psi with the vacuum hose to the regulator disconnected and pinched and 36psi with it reconnected.
possible cause
-clogged fuel line
-ICM malfunction
-low compression
-IAC malfunction
-O2 sensor circuit
wires were replaced 14 months ago, and tested to make sure they are firing.
i replaced the fuel filter and the car is running rich in all cylinders... its getting fuel.
we also took the hose off the regulator... no change.
thank you for the info!!!!
yeah i gotcha. when i first read his post it sounded like he had spent all this time and money throwing parts at it without any logical diagnosis, but he described the situation better in another post, and it made sense.
ok so ive tried everything but these 4. of those options i don't think its the o2 sensor as it idles fine. i dont think its a vtec malfunction because the motor screws up before the vtec crossover point.
iac or icm? what exactly do those entail im not familiar with them.
dunno what ICM is but i'm going to assume ecu. and iac is idle air control. (back of the intake manifold or if its an automatic it'll be under the TB(throttle body)
im working on a 99 ex that is having the same codes, and same issues
it runs poorly, and even stalls
p1399
just rebuilt the block for them
p1399
and you dont have a bent valve right cus it was looked at right? hmm unless your o2 sensor was ****ed up and you were running rich and it melted your cat...maybe the IAC then. i would get it diagnosed somewhere possibly if your not getting youve done almost everything. it also could be warped pistons...
Everything I have read is regards to ICAV talks about a screwed up idle... the car idles is fine in this case.
How much ignition voltage are you getting and whats your fuel pressure?
it may appear to have good spark but it takes a certian amount of voltage to detonate on time.
And the iCM is replacable but its in the dizzy itself.
MY buddy had the same problem, running rich and the not reving past 3000, does it try to dies if you press the gas more then just a little?
