p28 injector driver question
Old 12-01-2011, 08:27 AM
jm2000turbo's Avatar
Post p28 injector driver question
I have a p28 ecu with damaged injector drivers. I have a p06 and p2e ecu and was wondering if the injector drivers from either of these would be compatable in my p28 if i were to desolder and solder in good ones?
jm2000turbo is offline
Old 12-01-2011, 08:33 AM
The Grumpiest
grumblemarc's Avatar
Default Re: p28 injector driver question
Just get a new ECU before you burn it up.
grumblemarc is offline
Old 12-01-2011, 09:59 AM
I've damaged my injector drivers due to running without the resistor box the first time i ran the car. How would changing out the drivers cause my ecu to burn up if I have the resistor box wired in? I just want to know whether or not they are the same
Old 12-01-2011, 10:06 AM
Jdubbs6101's Avatar
Yeah they are the same you could also solder in the components for vtec on those ecus I'm sure if you did a search you could find what to add and where to put it Honda only used 2 or 3 different boards for all those ecus and if you're going to open your ecu replace the electrolytic capacitors they only have a 15 year life expectancy
Jdubbs6101 is offline
Old 12-01-2011, 10:18 AM
The Grumpiest
Re-read. Where did I say any of that?
I'm talking about your soldering job. Why risk destroying two ECUs?
Old 12-01-2011, 11:33 AM
ok thanks Jdhubbs.
Old 12-01-2011, 04:24 PM
Former User's Avatar
Please PM me if you have questions about why your threads have been closed.
Former User is offline
evosix
Engine Management and Tuning
05-23-2016 12:34 PM
Whiteintegra
08-02-2006 10:37 PM
TURBO DC2
05-28-2005 10:41 AM
krazeemidget
11-11-2003 10:05 AM
dragonrcr
11-29-2002 05:44 PM
Quick Reply: p28 injector driver question
