the "d' is blinking
Old 07-31-2011, 02:19 PM
f88bonilla's Avatar
Default the "d' is blinking
my 00 ek b20 the D is blinking when i put the car in drive
Old 07-31-2011, 02:45 PM
Former User's Avatar
Default Re: the "d' is blinking
Pull the CEL codes. A transmission code is being thrown.
Old 07-31-2011, 03:27 PM
Seagull Management
94EG8's Avatar
If it's a B20 in a '96 - '00 it's going to continue to blink. It's near impossible to do an automatic B-series swap and have it work properly.
Old 08-01-2011, 07:01 PM
f88bonilla's Avatar
also when i put the car in drive and put my foot on the gas the car will not go it takes a while to accelerate?? anyone know why
Old 08-01-2011, 07:24 PM
bpl0807's Avatar
Did you just recently swap it? If so did you fill the torque converter with Honda ATF before putting everything together?
Old 08-01-2011, 07:30 PM
f88bonilla's Avatar
almost a year ago and it jus started acting funny "d" light blinks and when i put my foot on the gas it takes a while to accelerate all the other gears work fine
Old 08-09-2011, 09:23 AM
f88bonilla's Avatar
Ok so I got a b20 & ls trans. When I turn the car on the "d" light blinks when I put the car in drive and press the gas the car doesnt wanna move. I half to start it in second to drive it.any help? Its a 00 ek with a b20 swap ls trans
Old 08-09-2011, 09:26 AM
You haven't yet responded to 94EG8's comment.
Old 08-09-2011, 09:44 AM
f88bonilla's Avatar
Yes its 00 n its a b swap
Old 08-09-2011, 09:46 AM
The Grumpiest
grumblemarc's Avatar
Then you have your answer.
Old 08-09-2011, 10:00 AM
f88bonilla's Avatar
I dont care that the d light blinks.. When I hit the gas the car wont go I half to drive it in 2nd
Old 08-09-2011, 10:02 AM
Are you under the impression that the blinking D4 light and driving problem are unrelated?
f88bonilla's Avatar
Any1 know what the problem could be?
Old 08-09-2011, 10:04 AM
f88bonilla's Avatar
Im jus tryin to figure out why the car wont go when its in d4
Old 08-09-2011, 10:06 AM
f88bonilla's Avatar
No I think it is related.. D4 blink n car wont move unless its in 2nd
Old 08-09-2011, 10:07 AM
The Grumpiest
Who did the swap?
Old 08-09-2011, 10:08 AM
I'll try my best to make this simple for you. (based on 94EG8's post)
1) The blinking D4 light indicates that the ECU and transmission are unable to communicate with each other.
2) As long as the D4 light blinks, the car won't be driveable.
3) There is no simple solution for the D4 blinking light in your automatic B-series swap.
4) You needed to do more homework before you decided to do an automatic B-series swap.
Old 08-09-2011, 10:10 AM
f88bonilla's Avatar
Thanks
Old 08-09-2011, 10:13 AM
Good luck
f88bonilla
08-09-2011 08:55 AM
DRES051K
08-27-2010 11:22 AM
killahatch
04-06-2009 07:21 PM
Quick Reply: the "d' is blinking
