cv axle stuck
Old 04-20-2007, 06:06 PM
compo1's Avatar
Default cv axle stuck
i am trying to put in a new cv axle..it goes in almost the whole way and stops about 1 inch from where it needs to seat...i lubed it and tried pushing on the inner cv joint housing while rotating it to line it up with the splines...it does not budge...in the box it came in there were instructions showing how to take the boot off the inner cv joint and separate the cv axle... and seat the inner cv joint and then reassemble the cv axle...has anyone tried this method...it comes with another clamp to reseal the boot thanks in advance....compo1
Old 04-20-2007, 06:08 PM
SkertySkerty's Avatar
you can lube it all you want if it has any dirt whatsoever on it its not going in happened to me several times all i did was put an air chuck on my compresser and cleaned it off 100% slid in like a dick on a wallowed out hole
Old 04-20-2007, 06:56 PM
H-T Poker champion
Hatchy-Ownzjo0's Avatar
Default Re: cv axle stuck (compo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compo1 &raquo;</TD></TR><TR><TD CLASS="quote">in the box it came in there were instructions showing how to take the boot off the inner cv joint and separate the cv axle... and seat the inner cv joint and then reassemble the cv axle...has anyone tried this method...it comes with another clamp to reseal the boot thanks in advance....compo1 </TD></TR></TABLE>
Do NOT do that.
You can do it put your back into it.
Seriously, it's not that easy to get in there. You really need to put some muscle into it. It will slide in, it just takes a lot of pushing and strength.
Whatever you do, do not disassemble the cv joint. That will only make things more complicated..
Old 04-20-2007, 07:10 PM
hondamark35's Avatar
make sure the car is well supported. with the hub assembly loose from the lower ball joint use the hub and brake rotor as a hammer and knock the axle until it goes in. you won't hurt anything doing it this way unless you already hurt something. i do it like this every day
Old 04-20-2007, 07:48 PM
compo1's Avatar
Default Re: cv axle stuck (hondamark35)
thanks for all the help and suggestions...back at it tomorrow a.m.
DarkBB4
04-22-2007 09:29 PM
ahloung
15
03-14-2006 11:52 AM
athoughts
16
09-27-2005 12:49 PM
gtowni3
12-24-2004 08:09 AM
Black_Accord
07-14-2003 08:08 AM
Quick Reply: cv axle stuck
