CTR transmission specs? - Honda-Tech
Old 12-24-2004, 05:12 PM   #1
Default CTR transmission specs?
I cant seem to find these online. Do they come with an LSD like that ITR transmission? What are the gear ratios? Final drive? do they have dual cone 1 and 2nd gear synchros like the B18C5?
JoeB18R is offline   Reply With Quote
Old 12-24-2004, 05:17 PM   #2
Andres-eh2's Avatar
On this site when we say search it also means to look through google if you have too.
http://tech.hybridgarage.com/tech/bseries.html
Andres-eh2 is offline   Reply With Quote
Old 12-24-2004, 05:22 PM   #3
Default Re: (Andres-eh2)
ask a computer, ask a person ON a computer. same result. thanks BTW.
Old 12-24-2004, 07:42 PM   #4
hayabusa160's Avatar
Default Re: CTR transmission specs? (JoeB18R)
the gear ratio same as the b18c5
has lsd etc.
hayabusa160 is offline   Reply With Quote
Old 12-24-2004, 08:25 PM   #5
Hybrid96EK's Avatar
Quote:
Same gearing as ITR tranny. Dual cone synchros in all gears as far as I know, just like ITR. Has same LSD as ITR. 4.40:1 final drive.
I run a CTR tranny with a JDM ITR final drive in my hatch. Very important part if you want to run good times!
Hybrid96EK is offline   Reply With Quote
Will this break my transmission? josephcmiller2 Transmission & Drivetrain 8 01-06-2012 12:48 AM
gears starting to grind hojoR Honda Civic / Del Sol (1992 - 2000) 5 08-16-2009 09:32 PM
Detailed Questions of Diferrence: LS VS. GSR Tranny lmike6453 Transmission & Drivetrain 14 09-14-2008 08:59 PM
Transmission Questions LS vs. ITR, Synchro Questions too! b18bEKcoupe Tech / Misc 7 06-29-2007 12:18 AM
need help on transmission problem dayaftertomorrow Tech / Misc 5 01-02-2005 09:32 PM
Tags
ctr, drive, final, gear, gearing, honda, jdm, ratio, ratios, spec, specs, tech, tranny, transmission, transmition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
