CTR lsd tranny fluid?
My S4C lsd tranny has a slight grind at higher rpms when shifting into 3rd. I'm going to change the fluid this weekend. Is there any specific fluid I need for an lsd trans? My 2 choices were either Honda MTF or GM/ pennzoil synchromesh. Any advice?
Also, if anyone could tell me the fluid capacity that'd be great too
Re: CTR lsd tranny fluid? (schuetts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schuetts »</TD></TR><TR><TD CLASS="quote">My S4C lsd tranny has a slight grind at higher rpms when shifting into 3rd. I'm going to change the fluid this weekend. Is there any specific fluid I need for an lsd trans? My 2 choices were either Honda MTF or GM/ pennzoil synchromesh. Any advice?
Also, if anyone could tell me the fluid capacity that'd be great too </TD></TR></TABLE>
Synchromesh isn't going to cure worn teeth on a synchro. It might be easier for worn teeth to cut through, but you still haven't addressed the issue correctly. I would use nothing else other then Honda MTF. If the grind is still there after a fluid change (which it most likely will be) then its time to change the synchro.
Re: CTR lsd tranny fluid? (Hybrid96EK)
Alright. Well I plan on fixing it this winter but was hoping that changing the fluid would help a bit till then. I'll change it anyways. Thanks for the replies everyone
Cool Cool Island Breezes. BOY-EE
Re: CTR lsd tranny fluid? (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver »</TD></TR><TR><TD CLASS="quote">B16 trannies take 2.3 quarts last time i did mine...</TD></TR></TABLE>
yep. you just have to drain it all the way. I pull the plug, go make some 'za and watch TV or do whatever else for 2 hours ...maybe hit up some internet ****....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schuetts »</TD></TR><TR><TD CLASS="quote">Is there any specific fluid I need for an lsd trans?</TD></TR></TABLE>
No, but I'd recommend Redline MTL.
Re: CTR lsd tranny fluid? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">I'd suggest otherwise.......</TD></TR></TABLE>
Why's that?
Why's that?
Re: (Blk00EJ8)
acura has their own version with synchromesh in it to help with the problems that the rsx's where having. I put it in my old da gsr that was starting to grind and it fixed it. Or at least quited it down a lot.
Re: (niptek)
i used 10w-30 and i grinded 3rd, dropped that for the new honda mtf last week and the trans feels brand new. its a pretty awesome feeling when youre 15 year old trans feels brand new
