Cruise Control Vacuum
Old 08-22-2016, 12:55 PM
96Miata!'s Avatar
Default Cruise Control Vacuum
Hello all,
I daily drive a 96 civic lx. It has 300k miles on the body and recently put in a lower mileage motor out of a hx/cx or something that did not have cruise control. Car runs perfect except there is no where to hook the the last vacuum line for cruise control. The port is not on the back of the manifold like the lx manifold. What vacuum line can I T into instead of replacing the manifold its self?
Thanks!
Old 08-22-2016, 01:05 PM
GDD Member
slomofo's Avatar
Default Re: Cruise Control Vacuum
Fuel pressure regulator or EVAP purge vacuum
Old 08-22-2016, 01:31 PM
Former User's Avatar
Originally Posted by 96Miata!
Hello all,
Thanks!
Where is the IM from the old engine?
A CX and LX have a D16Y7 and an HX has a D16Y5.
Old 08-22-2016, 02:13 PM
96Miata!'s Avatar
Either way they don't have cruise. Manifold is on original motor. It would be much easier to T it off something else than switch manifolds in the car.
Old 08-23-2016, 10:19 AM
96Miata!'s Avatar
Does it matter which one is used for cruise. Does anyone have a picture of the EVAP purge vacuum? Just to make sure I use the correct one.
Old 08-24-2016, 04:33 AM
96Miata!'s Avatar
bump
Old 08-25-2016, 03:59 AM
96Miata!'s Avatar
Bump
Old 08-25-2016, 04:07 AM
mk378's Avatar
You can tee into any line that goes directly to the manifold. The purge solenoid can be identified by it having a hose going to the EVAP canister on the firewall. You want to tee into the other hose between the solenoid and the manifold.
Old 08-25-2016, 04:54 AM
96Miata!'s Avatar
Thank you sir! I will give it a try this weekend.
Old 08-25-2016, 06:32 AM
Fish Twig
tony_2018's Avatar
Yes, T off of any vacuum source or just get @slomofo to suck on it while you drive.
Old 08-31-2016, 08:48 AM
96Miata!'s Avatar
T'd it off the fuel pressure regulator. works great now
EJ8_Man
01-18-2011 08:55 PM
JDMtype Eg6
07-31-2006 05:42 PM
b18cEK
20
06-21-2005 10:29 AM
hulk252
04-23-2005 05:31 PM
retriever99
05-21-2004 11:17 AM
Quick Reply: Cruise Control Vacuum
