Cruise control not working!!
Old 09-18-2008, 09:22 PM
Bob Dole!'s Avatar
Default Cruise control not working!!
I press the set button and the cruise control light doesn't come on, nor does it maintain speed. The light on the cruise button also doesn't come on when you press it, however that stopped working long before the cruise stopped working. Looked for the fuse and it seems there is no cruise control fuse under the dash or in the engine bay. By the way this is for a 93 del sol with the d16z6. Any info/help would be appreciated!!! Sorry for the novel!
ISSUE RESOLVED:
The problem was the switch on the clutch pedal. It didn't make good contact with the clutch pedal. Adjusted it and worked flawlessly.
Old 09-18-2008, 09:28 PM
civicjoe's Avatar
Default Re: Cruise control not working!! (Bob Dole!)
I'd get out the multimeter and check that's it's getting power.
Old 09-18-2008, 09:31 PM
Bob Dole!'s Avatar
Default Re: Cruise control not working!! (civicjoe)
I was afraid of that response! Seeing how I don't happen to have a multimeter!
Old 09-18-2008, 09:55 PM
civicjoe's Avatar
If you do a lot of diagnosing and such it's a great investment. Get a digital one for 30-40 bucks at radioshack, I was hesitant about getting one but's it's one of my favorite toys...umm...tools. Otherwise I don't know what to tell you, I would say it's either:
A) not getting power
B) Bad component
Multimeter will tell you which.
Old 09-18-2008, 10:12 PM
Bob Dole!'s Avatar
Well shucks! I guess I'll double check all the connections and if that doesn't work, break down and buy a multimeter!
Old 09-18-2008, 10:44 PM
civicjoe's Avatar
I'm not sure if any of the connections are exposed as I've never had stock cruise control before but make sure you keep a good eye out for corrosion.
Old 09-19-2008, 04:43 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Make sure you've got vacuum going to the cruise. It absolutely won't work without it. Also check the throttle cable - there's one that runs from the cruise to the back of the gas pedal.
Old 09-19-2008, 01:02 PM
Bob Dole!'s Avatar
Default Re: Cruise control not working!! (Vindicator9000)
It has the electronic cruise same as 92-95 civics, not the vacuum system the 96-00 have. I thought about the throttle cable too, but I would think the light would at least come on if that was the case, plus when I operate the cruise cable by hand, the throttle body opens and closes just like it should. Man I wish it was as simple as the cruise cable!
Old 09-19-2008, 01:32 PM
wow, my bad. I thought they all had vacuum cruise.
Good luck.
Old 09-19-2008, 08:11 PM
Bob Dole!'s Avatar
Thanks! Any more suggestions before I go out and get a multimeter?
Old 09-20-2008, 12:13 PM
Bob Dole!'s Avatar
Bump for more suggestions!
Old 09-20-2008, 08:53 PM
Bob Dole!'s Avatar
Suggestions?
Old 09-20-2008, 09:23 PM
H-T White Ops
NOFX's Avatar
Default FV-QR
I know here it doesn't mention a fuse:
https://honda-tech.com/zerothread?id=1966666
But I'd pull each one looking for a bad fuse. The fifth gens use fuse 12 for cruise control.
Old 09-21-2008, 12:32 AM
Mr. Em1's Avatar
maybe the module itself went bad, if you can borrow one, try and test it if not try and get that multimeter and see if it is getting power. good luck
Old 09-21-2008, 07:45 PM
Bob Dole!'s Avatar
Default Re: FV-QR (NOFX)
I noticed in the thread nofx posted fuse #24 is the cruise fuse in a del sol. However my cluster and all that still works and the fuse was not blown. In fact no fuse was was blown in the whole fuse panel! So its likely that its the module itself. I'll likely get a multimeter tomorrow and find out for sure.
eskudo12791
06-14-2010 07:26 PM
mac_24_seven
08-31-2009 09:15 AM
Sweetsystem
08-26-2008 01:58 PM
Juan_Mitosis
06-19-2008 11:13 PM
Hairy Gorilla
02-12-2005 02:31 PM
Quick Reply: Cruise control not working!!
