Cruise control button wiring diagram and removal
I have a 95 civic ex. I have oem cruise control but the system is removed. I want to wire up interior footwell lights to this switch so as to keep a clean look. How do i remove the switch and how would I go about wiring this up? The switch light still works so I know theres power to the switch.
Re: Cruise control button wiring diagram and removal
If the switch is no longer powered, what colored wire do i run the hot from the battery to, and what colored wire do i connect from the switch to the "hot" on the light strip? Also, should I tie in the illumination wire to the wire going to the light strip so that when the strip is powered the button lights up? Or is the illumination built in?
06Accord5SPD
02-22-2016 03:10 PM
