crank seal - how hard is it to replace?
Old 03-11-2009, 12:43 AM
wudini's Avatar
Default crank seal - how hard is it to replace?
00 Civic EX
D16Y8
I need to replace my crank seal, I'm losing about a quart of oil every 2-3 weeks and I'm 100% positive it's leaking from there. has anyone every changed one on a D-Series? Honda quoted me about $550 to replace the seal and the timing belt. Just lost my job @ Circuit City so I don't really wanna go that route. I have above average mechanical skills especially when dealing with D-Series motors and a friend who's a mechanic who would help me.
Old 03-11-2009, 07:31 PM
wudini's Avatar
Default Re: crank seal - how hard is it to replace?
bump.
Old 03-11-2009, 07:34 PM
92civicx's Avatar
rear main seal near next to tranny ?
Old 03-11-2009, 07:35 PM
Meoshe's Avatar
Not too bad if you have above average mechanical skill. A little more work than doing a timing belt but not much. Make sure surfaces are CLEAN so things don't gall the crank. Helms would come in handy too for reference.
Old 03-11-2009, 07:46 PM
wudini's Avatar
no the seal on the crank inside the timing cover.
Old 03-11-2009, 07:47 PM
wudini's Avatar
i do have a helms & thanks for the advice. ;]
Old 03-11-2009, 08:47 PM
honda.lioness's Avatar
If you have never changed a timing belt before then your friend the mechanic is going to be essential. You should use a shop manual or at least a Chilton's. Replacing the crank seal and cam seal is usual when doing a timing belt, because the interference removal is the same. I have found the best tool for removing the old seal to be an ordinary liquor bottle corkscrew. Do not mar the shaft as you are removing the seal. To install the new seal:
1.
Cut a piece of plastic from a plastic soda bottle. Cut it to fit as described below.
2.
Make a cylinder out of the plastic and insert it into the new seal. Use motor oil to pre-lubricate surfaces that come into contact in the next steps.
3.
Slide the plastic cylinder (with new seal) over the crankshaft end. Be careful that the seal's lips yada do not fold over.
4.
Push the new seal into place with a piece of pipe, sockets, washers or whatever fits over the crankshaft end and can push against the new seal evenly.
5.
Pull the plastic cylinder off.
This is not a perfect technique but it's darn hard to get that seal on straight otherwise.
Old 03-12-2009, 01:41 AM
B2KHonda's Avatar
i did mine on my old f series and it wasn't to bad and it was my first. haynes helped out alot.
gl man
Old 05-01-2009, 08:01 AM
blkSteelies's Avatar
is there a diy out there? i have been trying to diagnose an oil leak on my 98 for some time now and once I got the car on a list it seems to be the crank shaft seal.
Old 09-25-2014, 07:12 PM
FaboCR's Avatar
Guys, I know this post is an old one, but I am in the need to replace the seal as well, besides the timing belt. I would have a mechanic friend to help me but has been really hard and I need my car up and running. It is an EF with y8 engine. For some reason, the screw that holds the crank pulley came off, as well as the securing latch that keeps the pulley in place. Since it became loose, the pulley rubbed against the crankshaft. I checked the crankshaft and it all looks ok, but have to replace the pulley, so I want to take advantage of this as I have a leak in the seal that I want to work with.
Old 09-25-2014, 07:45 PM
Fish Twig
tony_2018's Avatar
Your post has nothing to do with the crank seal.
pcconway
09-11-2016 01:07 PM
pjr710
19
11-27-2011 11:22 PM
m00nr0ck Si
05-31-2008 07:22 AM
EG civic
07-08-2006 08:02 PM
VTgringo
08-11-2004 03:47 PM
Quick Reply: crank seal - how hard is it to replace?
