Idle Drop At Complete Stop And Car Dies
Ok Heres The Deal My Car Beens in good conditon all year and this one day i was on the freeway and a coupe pulled up we drop gears and then evertyhting was ok then i tride to drop in forth and went to secound =( the whole car jerk and we stop then when at a complete stop the car dies. we turned on the car then the Idle drops to 0 then dies but when we rev the motor the car comes back on. when driveing agian the car is ok but at a complete the idles drops and the car dies
did valve adjustment
check all fuse (main relay)
check for sparks
check the dizzy
fuel pump
throttle body needle check for Idle
Nothing Help
NEED SOME SERIES HELP!
check for sparks
check the dizzy
fuel pump
Nothing Help
Re: Idle Drop At Complete Stop And Car Dies
strange, check to make sure your IACV isnt bad, also i had a MAP sensor do almost the same thing on mine... not sure thats what yours is but figured its a good place to start...also is the car throwing codes? if so, post them, that will help pinpoint the problem
**** it decied to just change the head and when i did there was some bent valve and when i changed it, it turned out to be ok
