Coolant Reservior overflow causing overheating... - Honda-Tech
Old 04-30-2006, 06:50 AM   #1
Robs_B18c's Avatar
Default Coolant Reservior overflow causing overheating...
Ok my uncle has a eg 4 door it's all stock automatic. The car keeps overheating and coolant reservoir overflows. He just put a brand new t-stat, radiator with brand new cap and still the same problem. Help would be very appreciated.
Modified by Robs_B18c at 9:12 AM 4/30/2006
Robs_B18c is offline   Reply With Quote
Old 04-30-2006, 07:25 AM   #2
Chiovnidca's Avatar
Default Re: Coolant Reservior overflow causing overheating... (Robs_B18c)
Quote:
Have you done a leakdown test? May have a blown headgasket.
Chiovnidca is offline   Reply With Quote
Old 04-30-2006, 07:31 AM   #3
Robs_B18c's Avatar
Default Re: Coolant Reservior overflow causing overheating... (Chiovnidca)
No I haven't. I don't have a leakdown tester but I do have a compression tester I'll post the update. Anymore ideas would be helpful as well.
Old 04-30-2006, 12:03 PM   #4
Robs_B18c's Avatar
ttt
Old 04-30-2006, 12:39 PM   #5
ITR EG's Avatar
on my b18c, my idle started surging so i popped the hood to adjust the idle and there was coolant everywhere. it was all pushing out the coolant overflow tank. I replaced the head gasket and it fixed it right up.
ITR EG is offline   Reply With Quote
Old 04-30-2006, 12:48 PM   #6
E.46's Avatar
u ever flushed out your coolant, or have you ever added any additive **** to your coolant???
E.46 is offline   Reply With Quote
Old 04-30-2006, 03:55 PM   #7
Robs_B18c's Avatar
Default Re: (visionpromo)
Quote:
No I have not
Old 05-02-2006, 08:12 AM   #8
Robs_B18c's Avatar
ttt
Old 05-02-2006, 08:17 AM   #9
flood's Avatar
Default Re: (Robs_B18c)
Air bubble in teh cooling system?
COuld heat up expand, push coolant out into overflow. Cools down, sucks it back in.
Does the overflow tank drain after cooling down? Any erratic temp guage behavior?
Just a thought.
flood is offline   Reply With Quote
Old 05-02-2006, 08:26 AM   #10
snatch's Avatar
Default Re: (flood)
I always been under the impression that if your coolant overflow overflows then the headgasket is bad. Compression test might tell you if it blown, leakdown test would for sure. But I understand not having a leakdown tester.
snatch is offline   Reply With Quote
Old 05-02-2006, 08:34 AM   #11
I3ooS710's Avatar
Default Re: (******)
More than likely, it's your headgasket. If you want, you can try to run the car without a thermostat and see what happens. At least that'll eliminate the possibility of it being the thermostat, although most people will still say it's the headgasket.
BTW, are your fans turning on at the correct time?
Also try bleeding the system.
Hope you solve the problem.
I3ooS710 is offline   Reply With Quote
Old 05-02-2006, 08:39 AM   #12
Robs_B18c's Avatar
yeah I was thinking it's the headgasket too. I'll try running it without the t stat and see what happens. and yes the fans are turning on at the correct time and I bleed the coolent system already
Old 05-05-2006, 10:41 PM   #13
Robs_B18c's Avatar
ran without the t-stat and still the same problem
Old 05-06-2006, 01:36 PM   #14
Robs_B18c's Avatar
Old 05-06-2006, 01:40 PM   #15
schardbody's Avatar
stick your nose up to the radiator w/ the cap off, alot of times if its pushing exhaust out the radiator from a blown head gasket you will know by smelling it. also, i wouldnt rule out the water pump, the impellar blades could be completely gone and not moving any coolant. also make sure the fan is working. just because its pushing coolant out the overflow your not garenteed to have a blown head gasket, its designed to let the coolant flow into the overflow to relieve pressure so you dont blow the radiator and stuff.
schardbody is offline   Reply With Quote
Old 05-06-2006, 01:43 PM   #16
ghost_ryder35's Avatar
Default Re: (schardbody)
check your oil to see if its milky (coolant mixing with oil) and also check to see if you are burning any coolant (white smoke). I think if you changed all that stuff then it is probally the head gasket. Check the waterpump?
ghost_ryder35 is offline   Reply With Quote
Old 05-07-2006, 10:43 AM   #17
Robs_B18c's Avatar
Default Re: (ghost_ryder35)
Old 05-07-2006, 11:35 PM   #18
Robs_B18c's Avatar
Old 05-10-2006, 02:09 PM   #19
Robs_B18c's Avatar
fvdzsf
Old 05-10-2006, 02:11 PM   #20
tatmark1's Avatar
i had this problem before my swap. head gasket was fucked. i had no oil in coolant or vice versa. let car run with out cap on and push throttle down a little and i bet old faithfull shoots up in yer eye
tatmark1 is offline   Reply With Quote
Old 05-10-2006, 02:19 PM   #21
tatmark1's Avatar
hey i got a d series auto tranny yer looking for!
(WI) Midori Green EK Hatch. $1200 !!!! Robs_B18c Mid-West (Sales) 32 04-22-2012 08:01 AM
(WI) 16" 4x100 Slipstreams Robs_B18c Mid-West (Sales) 24 02-10-2012 12:24 PM
Vouch Thread !@!!@!!@!!@ Robs_b18c Robs_B18c For Sale 0 09-27-2007 11:27 AM
WTB: DOHC ZC longblock Robs_B18c Mid-West (Sales) 3 05-07-2007 06:14 PM
1990 Acura Integra b20 Swap Clean (WISCONSIN) Robs_B18c Vehicles for sale 27 11-30-2004 09:52 PM
Tags
1996, 2002, bottle, civic, coolant, crv, honda, jetta, overflow, overflows, pump, pushing, reservoir, volkswagen, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
