Coolant problem
Old 12-31-2001, 09:18 AM
Spartanic's Avatar
Default Coolant problem
For the past few months I've been losing a lot of coolant so I shecked around the water pump and found that it was leaking from the weeper holes so I changed the o-ring gasket with a new one and thought that it'll solve my coolant leaking problems, but it didn't. It still leaks and I'm not sure if I should just change the whole water pump or not. I read in the service manual that you'll only need to change the water pump when it makes a houling sound but if it leaks a lot from the weeper holes than you need to change the o-ring gasket. Any solutions?
Old 12-31-2001, 09:24 AM
DragII's Avatar
Default Re: Coolant problem (Spartanic)
pump is dying when it makes that sound...change it out...you may be boiling coolant away
Old 12-31-2001, 09:27 AM
Spartanic's Avatar
Default Re: Coolant problem (DragII)
Thanks for your reply DragII, but my water pump isn't making the houling sound, its just leaking again even though I changed the o-ring gasket.
Old 12-31-2001, 09:29 AM
DragII's Avatar
ooops! read it wrong...however...although the pump is expensive...it does not make sense to go through the labor of changing the gasket with out doing the whole pump.
Old 01-01-2002, 04:46 AM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
drag is correct. do the pump.
cstap
10-10-2013 06:34 AM
tony_yang
Honda Civic (2006 - 2015)
01-28-2011 03:49 PM
RexTypeS
Acura TL, RL & ZDX
06-22-2006 04:26 PM
twistedbydezign
09-13-2005 10:24 AM
spaceman
04-21-2004 06:17 AM
Quick Reply: Coolant problem
