coolant gone?!? no leak no overheat!?
Old 06-06-2008, 11:46 PM
soulo's Avatar
Default coolant gone?!? no leak no overheat!?
Can someone give me some advice or answer my following questions plz....
when my engine is running for 30 mins the Radiator drain out the coolant to the spare tank.....and i have to add in coolant everytime i drive.....Does anyone know whats wrong?
Parts i replaced:
Themostat
Radiator
Upper / Lower Radiator hoses
heater hose
Themo Fan switch
Old 06-07-2008, 03:24 AM
mohater's Avatar
Default Re: coolant gone?!? no leak no overheat!? (soulo)
If I'm reading that properly:
Your reserve tank is overflowing after ~30 mins of driving and coolant is pouring out?
I can think of two things:
Your radiator cap is defective and is allowing too much coolant out w/o reaching the proper pressure.
You head gasket has a leak at the header, and the exhaust is just adding more pressure to the coolant system. This additional pressure is what is forcing the coolant to the reserve tanks.
Buy a new cap, if it still happens do a compression test.
Old 06-07-2008, 10:18 AM
soulo's Avatar
there is no leak from th reserve also. just all the coolant is gone from the radiator and the reserve is full. also this happen after changing the headgasket
Old 06-08-2008, 07:49 AM
blkegcoupe's Avatar
Location: ....................................................................................................
Default Re: (soulo)
bump....happening to me too
Old 06-08-2008, 10:14 AM
SiREJ8's Avatar
It has to be going somewhere! I'd drain the oil into a clear container and let it sit, you'll then be able to see the coolant if present...
Also another way is to pull the plugs and see if they are green from coolant
pressure testing the cooling system also works!
Old 06-08-2008, 10:28 AM
ke98248's Avatar
Sounds like headlift to me.. I remedied the situation with ARP head studs and a new OEM headgasket
prodjay10
Honda Civic (2001 - 2005)
05-27-2015 09:23 AM
alvinahmed
09-16-2012 09:32 AM
mickey513
12-20-2004 02:22 AM
satintegra
06-06-2002 11:56 PM
Quick Reply: coolant gone?!? no leak no overheat!?
