cold engine compression test vs hot engine compression test
Old 07-13-2009, 06:34 PM
skaternak's Avatar
Default cold engine compression test vs hot engine compression test
is there a difference in psi results. cause my car been sitting in the garage for 3 weeks and i did a compression test and it was average 60 psi. is that bad or does it vary with engine temp?
Old 07-13-2009, 06:57 PM
tw1tch's Avatar
Default Re: cold engine compression test vs hot engine compression test
You have to have the motor at running temp. Doing it on a cold motor is pointless since it doesn't tell you anything. 60psi would mean the motor was done if it was fully heated up. Drive for a few minutes til it's up to temp and do it again
Old 07-13-2009, 07:26 PM
skaternak's Avatar
because my car wont start, and i was doing it at a cold temp. so low compression would be low if its a cold engine?
Old 07-13-2009, 07:30 PM
Ruben19's Avatar
i do my compression test with a cold engine
Old 07-13-2009, 08:31 PM
ddd4114's Avatar
You will get different readings for warm and cold engines, but 60 psi is pretty low in either case.
Are you testing with an open throttle?
Old 07-13-2009, 09:52 PM
skaternak's Avatar
no throttle just cranking
Old 07-14-2009, 03:29 AM
ddd4114's Avatar
Test it again with the throttle open.
Old 07-14-2009, 05:21 AM
civic_driver's Avatar
Compression test is done on a hot engine. This way all the parts expand on heat and keep a better compression.
Old 08-09-2009, 05:33 PM
New User
97civicfan's Avatar
I understand that the compression test is better done with the engine hot but if your engine isn't starting how do you do that? I just did a test because I think my headgasket is blown. I'm getting 105psi in each cylinder and the minimum is 135. I would have thought at even at 105 it would at least start. Also, it seems odd that I have low compression in each cylinder. Any thoughts?
Old 08-09-2009, 05:38 PM
ddd4114's Avatar
If you ran the test with an open throttle, 105 psi is pretty low, even for a cold engine. However, it should still be able to start, even though it'll run like poop.
Sounds like trouble
Old 08-09-2009, 05:48 PM
FlewByU352's Avatar
X2 and 1st time I did a motor I didnt hold it WOT and i was like **** i need a rebuild. i was pissed and walked away for a second to get a drink and ran back out dugh it has to be WOT and then it was in spec.
r.etheridge
02-12-2011 05:31 PM
aalb1
04-06-2005 09:10 PM
itsmebeaner1987
10-31-2004 11:54 AM
atmo_monster
06-13-2004 09:12 PM
98R-1144
01-06-2003 09:50 PM
Quick Reply: cold engine compression test vs hot engine compression test
