code P1457
Old 10-27-2005, 10:27 AM
jorge99hx's Avatar
Default code P1457
My 99 civic failed emissions testing because of Code P1457. Does anyone know how I can fix this. I only have a couple of months to fix the problem so any help is much appreciated. Has anyone encoutered this before? If So, how did you fix it?
Old 10-27-2005, 10:44 AM
AK94GSR's Avatar
Default Re: code P1457 (jorge99hx)
P1457- evap bypass solenoid valve
well to test this u really need a honda HDS
but if u just want to get it fixed and not worry about anything, just order a new one
this is caused by water getting inside the valve and causing corrosion
call your local honda dealer
here is the part number
17012-S01-A00
Old 10-27-2005, 10:49 AM
EG1.8cT68's Avatar
Code 1457 can be any number of emmisions related problems. usually this code signifies that you have a large leak in your fuel tank system. It could be as simiple as a cracked hose or vaccum line or your ebsv could be bad.
Old 10-28-2005, 12:09 PM
jorge99hx's Avatar
how much does the EBSV cost? also, is it relatively hard to install or can it be done simply?
Old 10-28-2005, 12:19 PM
Former Moderator
B18C5-EH2's Avatar
Default Re: (jorge99hx)
99% of the time either someone left the gas cap loose or off, or the gas cap has been dropped and is allowing a pressure leak from the fuel tank.
Tighten the cap until it clicks a few times and have the code cleared.
If the code persists, then replace the gas cap.
If the code still persists THEN have a Honda dealership diagnose and repair it.
Old 10-28-2005, 12:20 PM
coquitlamEG's Avatar
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">99% of the time either someone left the gas cap loose or off, or the gas cap has been dropped and is allowing a pressure leak from the fuel tank.
If the code still persists THEN have a Honda dealership diagnose and repair it.</TD></TR></TABLE>
Do it
Old 10-28-2005, 03:43 PM
jorge99hx's Avatar
I passed the gas cap test. What I didnt pass was the obdII test. Once they conencted the plug I failed and Code p1457 was the result.
Old 10-29-2005, 07:42 AM
EG1.8cT68's Avatar
Usually the code for a gas cap is 1456 and is considered a small leak from the tank. My recommendation is to just take it to the dealer and have them look over the vehicle, they can hook the PGM or HDS to see how all the emissions sensors are reading. They usually charge an hour for this. Also if the sensors are all working properly they can use the smoke machine to find the leak.
Old 10-31-2005, 05:30 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: (EG1.8cT68)
I'll recheck the All Data here, but from my recollection P1457 is the tank code, while P1456 is the canister code...
I'll be back.
Old 09-10-2007, 08:23 PM
Wazup's Avatar
Default Re: code P1457 (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR &raquo;</TD></TR><TR><TD CLASS="quote">P1457- evap bypass solenoid valve
17012-S01-A00
I know this is ancient, but does anyone have a pic of this part?
i just wanna know exactly what part i am replacing, i got this same code after doing a y7 to y8 intake manifold swap
Modified by Wazup at 9:40 PM 9/10/2007
Old 09-11-2007, 06:11 AM
EE_Chris's Avatar
Default Re: code P1457 (Wazup)
I think it's Part 2.
Old 09-11-2007, 08:13 AM
Wazup's Avatar
Default Re: code P1457 (EE_Chris)
ah, thank you sir. i think mine just may have been corroded over time or something.
Old 11-09-2007, 01:02 PM
tekstyle's Avatar
when the BPV corrodes.. is it obviously visible? because mine isn't. both the 2-way and the BPV looks fine.
Old 11-09-2007, 05:24 PM
tekstyle's Avatar
Default Re: code P1457 (tekstyle)
here are some pics:
I found one of my hose split so I replaced it with what you see as a clear vinyl tubing. I don't think this makes a difference because the Y coupler is open on one end anyways.
brad8266
07-12-2022 10:28 AM
jd101
Honda Civic (2001 - 2005)
10-13-2017 03:50 PM
khan-civic
07-11-2013 01:47 AM
lankan-balla
06-03-2013 11:46 AM
MBlake55
12-13-2010 05:30 PM
Quick Reply: code P1457
