code 43 after 10 minutes driving.
93 del sol d15b7 engine all stock.
the car is running good no noises of any kind.
i took it up to 5-6k few times to check. and it revs up all the way to redline with no funky noises or clicks in neutral.
when i drive on the freeway the chek engine light comes on after about 10-15 minutes of driving.
when i accelerate from 2000 rpm untill about 4k the car has no power and at 4000 it just kicks and starts accelerating normally.
today took it to emissions testing and failed.
at 3000 rpm
the HC was over 200 norm is 100 something
the CO% was over 10 and norm is around 1.3
didnt even test the idle
heres what happened before that.
car threw 2 rods #2 and #3 2 holes in the block.
i bought a block and head that had a bad oil pump.(brearings were shot)
rebuilt that one and replaced the bad bearings(crank wasnt damaged)
it is running smooth no noises from the crank or bearings.
oil/water pumps all seals/gaskets and belts were replaced as well. so its all fresh except for rings and main bearings.
reused the intake and exhaust manifold from original blown engine.
heres my problem. the service manual shows the connector as 1234 pins but its hard to tell which way is up on the diagram.
and they dont list the wire colors.
i tested my O2 sensor green and white open circuit.
i tested the 2 black wires it whows 15 ohm resistance.
so which wires are the sensor and which are the heater?
and what else besides O2 sensor should i check?
(i put new fuel pump, new spark plugs,checked cap and rotor and wires they were within specs, injectors looked ok but havent tested them yet)
could a faulty injector cause such high CO readings?
at 3000 rpm
Re: code 43 after 10 minutes driving.
The two black wires are for the heater element of the O2 sensor. It's the other two that would cause code 43. Does unplugging the O2 sensor eliminate the performance problem (no power)? If not, then concentrate on the fuel system. Measure the fuel pressure and test the FPR.
strange. because i ran around and tested a few sensors at the junkyard and they all had no resistance on the colored wires but had 15-16 ohm on the black wires.
can they all be blown? i checked like 4-5 different models and even toyotas.
if it was fuel pump the car would choke on higher RPM instead of midrange.
it accelerates fine all the way through if i accelerate lightly. once i step on it a little bit it sounds like a wrx kinda. and then starts moving at around 4000.
almost forgot i retarded the timing a bit as well.
raverx3m
11
11-10-2011 06:24 AM
daymkimchee
10
02-16-2010 09:06 PM
