Clutch raddle?? Help
Old 05-25-2013, 07:39 AM
jdmsir4dr's Avatar
Default Clutch raddle?? Help
I have a 98 ek with a ls in it.....I noticed that when I turn on my car and the clutch pedal isn't pressed in I can hear a slight raddle. But if I slightly press the pedal in a little the raddle goes away. Usually the noise happens when I turn on the car in the morning or any time the car has been sitting for a while and the car is not warmed up. Once I drive it for a few minutes and the car is warm sometimes it goes away and comes back... Any idea what it is? The clutch grips fine and shifts perfect . I have no clue what it could be..I have a act 12lbs flywheel , heavy duty pressure plate and the street disc its all new only have about 900 miles on the parts. The clutch release bearing is also new purchased from advance auto parts....... Any suggestions thanks in advance
Old 05-25-2013, 10:50 AM
jdmsir4dr's Avatar
Default Re: Clutch raddle?? Help
Anyone
Old 05-25-2013, 01:58 PM
apexi_rsx's Avatar
throw out bearing is junk most likely.. ive had them do it to me after a new install.. id let it go until its so bad it needs replaced
Old 05-25-2013, 02:00 PM
jdmsir4dr's Avatar
Originally Posted by apexi_rsx
throw out bearing is going bad
U think so .. It has the same amount off miles as the clutch it was all new wen i put dem in
Old 05-25-2013, 03:15 PM
apexi_rsx's Avatar
only other thing could be pilot bearing in the end of the flywheel
Old 05-25-2013, 03:31 PM
jdmsir4dr's Avatar
Originally Posted by jbpnoman
Throwout bearing makes noise with foot on pedal. Input shaft bearing makes noise with foot off pedal. A shot ISB is a lot more likely than a TOB, with your explanation.
oh man ...how can I tell if the ISB is shot do I need to take the tranny all apart?
Old 05-26-2013, 12:50 PM
slimx's Avatar
Unless you got some high performance turbo etc build going on, nothing happens. Esp if the rattle is only happening in the mornings, that bearing will last you longer than your gearbox and engine lol.
When the rattling sound is bad, (bad enough that when you DRIVE at around 60k's you can still hear it) that's when u worry. And that wont be for ages!
Speaking from exp. had an integra da9 (3 gearbox and clutch replacements lol)
edit:
then again, best not to lead you on at the end of the day i haven't heard or seen it, wouldn't hurt to ask a local workshop it's not just a honda thing u know..
vlc92189
08-30-2006 11:10 AM
zeroek
12-31-2005 03:26 PM
SkoundrelUSA
11
11-21-2004 02:57 PM
SIKING
10-12-2003 05:29 PM
JONBLAZE55555
07-11-2003 11:32 PM
Quick Reply: Clutch raddle?? Help
