CLUTCH PROBLEM HAVE SEARCHED!
Old 11-24-2005, 02:10 AM
MiX
MiX's Avatar
Default CLUTCH PROBLEM HAVE SEARCHED!
Here is my problem. All of sudden my clutch pedal feels softer. And then starts to stick and then not spring back at all and sticks to the floor board. The weird part. The clutch has fluid and I HAVE BLEED the line once. The clutch pedal, when I pump it after awhile it will go back to normal condition and then after I drive without using it, it will go back to falling to the floor board. Another Thing, if this helps, when I hold the clutch pedal, like at a light, for a long period of time it does stay engaged.
1. Pedal falls to floor board
2. I have bled the line ONCE
3. Pedal will lose pressure over time
4. Pumping pedal will bring pedal back to life and work perfectly if I use it regularly.
5. Over time if not used, like driving on the freeway, ill lose pressure again.
6. Pedal does not lose pressure, even if I hold it down for along time, like at a light.
HELP! Whats my problem? Sucks I can not shift when I have no pressure.
Another thing when i bled the line it worked for about a week
Modified by MiX at 5:25 AM 11/24/2005
Old 11-24-2005, 03:24 AM
92ehatch's Avatar
Default Re: CLUTCH PROBLEM HAVE SEARCHED! (MiX)
i would say check for leaks to start, re bleed system, replace master/slave cylinder
Old 11-24-2005, 05:07 AM
Lmgrcivic's Avatar
Default Re: CLUTCH PROBLEM HAVE SEARCHED! (93egsedan)
sounds like the master cylinder is losing all its pressure if thats the case get the Omni they fixed all the flaws and work great now.
Old 11-24-2005, 05:14 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: CLUTCH PROBLEM HAVE SEARCHED! (Lmgrcivic)
New clutch master cylinder and/or slave cylinder. I would replace both.
Old 11-24-2005, 08:17 AM
Keith Pierson's bitch's Avatar
yup, start with the cheapest part fisrt, replace the slave cylinder, if that doesnt fix it then replace the master cylinder.
ramboPandA
05-04-2015 04:15 PM
mattthethug
09-26-2010 10:23 AM
sihonda
11-24-2006 05:43 PM
RTW DC2R
06-23-2006 07:42 AM
MiX
11-24-2005 06:59 AM
Quick Reply: CLUTCH PROBLEM HAVE SEARCHED!
