Clutch problem?
Electrician
Are you letting go of the clutch slowly while you rev slowly? Sometimes I catch myself doing that so I won't rev to high and waste gas (). Sometimes it vibrates and the whole front end shakes also.
Re: (onephatcivic)
Well you guys were right! Heat cracked and glazed flywheel plus a loose spring in the clutch plate. I just bought a new Fidanza 7.5 lb. flywheel to replace the stock one. Hopefully it works out OK.
Re: (Dimi)
yes you can. In my case though it was heat cracked pretty bad. PLus if i was going to spend the money to have it machined I figured mite as well go buy a new one.
