clutch pedal squeaks!
1998 honda civic ex
dx manual transmission
when i depress my clutch (when the cars off) it squeaks. i dont think its the pedal assembly because it sounds like the squeak is coming from the engine bay.
i know that my input shaft bearing is bad, but would that cause the squeak?
Re: (mr poo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr poo »</TD></TR><TR><TD CLASS="quote">what lubricant shoudl i use to lube it up?</TD></TR></TABLE>
don't listen to these teenage noobs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freeflyinrider »</TD></TR><TR><TD CLASS="quote">i have the same problem!!!! sounds like some sort of spring needs some lube or something, bump for an answer!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Clutch slave to clutch fork needs lubing. The tip of the slave is like a ball and it squeeks if not lubed.</TD></TR></TABLE>
they are both wrong. there is nothing to lube. the squeeking noise does occur, but only happens when the car is cold. once it has warmed up and you have started driving, the noise disappears.
Re: (MiNDTRiP03)
Well, I examined my slave cylinder today. I pinpointed the noise coming from there as I had someone press on the clutch pedal. I pulled back the rubber sleeve just slightly to see if there was any dirt or corrosion on the cylinder linkage, and BAM, a huge stream of black liquid shot out all over the engine bay. Each time I pulled it back, more liquid. It's obviously the clutch fluid (DOT 3). So, new slave cylinder for me.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
. the squeeking noise does occur, but only happens when the car is cold. once it has warmed up and you have started driving, the noise disappears.</TD></TR></TABLE>
no go
after driving my car for a while, i pull over, turn the engine off, and the squeaking still happens
no go
Re: (mr poo)
they are both wrong. there is nothing to lube. the squeeking noise does occur, but only happens when the car is cold. once it has warmed up and you have started driving, the noise disappears.</TD></TR></TABLE>
damn rude much?
To the OP, i've had this happen to me in my vehicle before as well. You can try to see if the noise is coming from the slave cylinder/clutch fork as ejoner said. Those moving parts when not lubed do make noise, sometimes it's noise generated from the tranny output shaft/throwout bearing not having any lube it can cause noise as well.
Or it can be your slave cylinder, internally making the noise.
Lube you can use if you want to go to honda, we use this stuff called hi temp urea grease at the dealership i'm at. Works well. Moly lube, red grease will work; autozone, advanced,etc.
Hope it helps.
damn rude much?
Hope it helps.
Re: (vrrodri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri »</TD></TR><TR><TD CLASS="quote">I put some grease in the fork to slave cylinder ball and the noise is gone, cold or hot....</TD></TR></TABLE>
could someone give me a picture of hwat this is?
Re: (b 1 6 a 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b 1 6 a 2 »</TD></TR><TR><TD CLASS="quote">Search. It's a common squeak.
https://honda-tech.com/zerothread?id=1038441</TD></TR></TABLE>
that solves nothing.
its been determined what causes the squeak, i'm asking what the part looks like so i can grease it
Re: (mr poo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agoldenau »</TD></TR><TR><TD CLASS="quote">
damn rude much?
actually no!
its been determined what causes the squeak, i'm asking what the part looks like so i can grease it</TD></TR></TABLE>
it is a common squeek. if you want you can try to lube up the parts on the tranny which were already mention (IMO, it's not the problem). or you can try to lube up the M/C as well, where i don't know but if you do find a place and it works, share the wealth.
damn rude much?
actually no!
Re: (vrrodri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri »</TD></TR><TR><TD CLASS="quote">fork to slave cylinder ball </TD></TR></TABLE>
can someone please post a pic to what this part actually is!
Re: (mr poo)
theres a mouse in your clutch line
leave some cheese in your seat with a very very very small bottle of vodka in the front seat with a blow up mouse
************ will be conked out in the front seat and all u have to do is pick him up, and put him in the woods
viola, problems solved
