Clutch Pedal Squeaking
Old 05-19-2010, 06:43 AM
heeltoehonda's Avatar
Default Clutch Pedal Squeaking
What would cause a clutch pedal to squeak when pushed in and let out?
Old 05-19-2010, 06:44 AM
apexi_rsx's Avatar
Default Re: Clutch Pedal Squeaking
i dunno mine does it too lol i dont worry about it
Old 05-19-2010, 07:24 AM
ken9's Avatar
There's little spring clip under the pedal.. It might be that need some lubricating..It wouldn't affect driving much. Just annoying squeaking..
Old 05-19-2010, 07:33 AM
Just a little wd40 do the job? Or should I use gear oil or something like that?
Old 05-19-2010, 08:31 AM
hondamark35's Avatar
use aerosol white lithium grease. it's good for springs and hinged joints because it goes on as a liquid then sets up thick to stay put and not drip off. i'm betting this is what the service manual recommends.
Old 05-19-2010, 09:07 AM
Resident Gearhead
BryanM.'s Avatar
Both my Civics have had this problem, in both cases it was the master cylinder itself that was squeaking as the piston went in an out.
Old 05-19-2010, 09:33 AM
forcefedeg01's Avatar
yep, white lithium grease fixed mine, now slave cyl makes noises cuz its dry where it meets the fork. i swear if its not one thing its the next..
Old 05-19-2010, 11:19 AM
apexi_rsx's Avatar
the sqweeking i noticed it was outside the car. it sounded to me the slave cylinder was sqweeking inside the fork as it pushed out
Old 05-20-2010, 05:56 AM
Thanks
Originally Posted by mcvtec
Both my Civics have had this problem, in both cases it was the master cylinder itself that was squeaking as the piston went in an out..
Hopefully it's just a joint, I guess I'll find out when I use the grease.
On your civic how did you fix it? Did you end up replacing the master cylinder?
That's the one thing I hate about older hondas, lol.
Did you ever get the slave sylinder noise fixed?
Mines deff comeing from around my clutch pedal.
Did you ever get it fixed?
Old 05-20-2010, 12:11 PM
Yea its quiet now, i used synthetic bearing grease (pennzoil) and put some in between the fork and the slave cyl mating surface. I had this happen before on my old turbo hatchy and it was quiet for more than 4yrs
Old 05-20-2010, 02:30 PM
jesman1988's Avatar
Nice information my civic just started to do this.
Old 05-20-2010, 08:52 PM
vsikwit's Avatar
OMG mine has been doing it for so long i was going CRAZY, thank u its gone now
Old 05-21-2010, 04:57 AM
Thanks for all the imput guys.
Magicdrag0n
Transmission & Drivetrain
07-17-2018 01:33 AM
integra3586
10-30-2005 09:20 PM
Johnny Gasparini
05-27-2005 06:55 PM
junglistgsr
12-07-2001 09:46 PM
Erik_Pb_Foot
09-09-2001 10:58 PM
Quick Reply: Clutch Pedal Squeaking
