clutch pedal goes to floor and doesn't come back up
Old 06-23-2010, 06:30 PM
ra64's Avatar
Default clutch pedal goes to floor and doesn't come back up
I unbolted the slave cylinder from the tranny b/c something was sqeaking a lot when I pressed the clutch pedal. I lubricated where the piston thing hits the shift linkage thing but I think i put it back together wrong because all the fluid started leaking out of the slave when I pressed the clutch pedal. I think i got it right now (I think I had the metal piston in backwards maybe but the clutch pedal still just does to the floor and I have to manually pull it back up. Is there air in the system now or do I still have something wrong?
Old 06-23-2010, 06:34 PM
Former User's Avatar
Default Re: clutch pedal goes to floor and doesn't come back up
Old 06-23-2010, 09:22 PM
ra64's Avatar
is it possible to bleed the system without a hose or bleeder kit?
Old 06-23-2010, 09:32 PM
delsolproblems's Avatar
Yes but it's environmentally unfriendly and makes it easier for air to get in through the bleeder valve while you're working. Suspending the hose in fluid prevents air from getting in.
Old 06-23-2010, 09:50 PM
I took way too long
slowman's Avatar
I've always just opened the bleeder screw, push clutch down, tighten bleeder screw, pull clutch up. Worked fine on all cars I've done it. Just an alternative solution I guess.
Old 06-24-2010, 04:42 AM
BlackEM2's Avatar
i was told...and this is how i did mine
pump clutch ( by hand since its sticking to the floor) i would say 10 to 20 times
and then hold it to the floor
and have a buddy open the valve and let the air out and tighten it back up
do this till u get the pressure back in the clutch
also make sure there is plenty of fluid in the resivor and replace as needed in the process since it will squirt it out
Old 06-24-2010, 05:48 AM
I use the One-Man Bleeder kit that costs $4 at Harbor Freight Tools.
http://www.amazon.com/gp/product/B00...ZJVZJDCP53P00X
Old 06-24-2010, 07:20 AM
1dumbscreenname's Avatar
BTW the squeaking is your throw-out bearing. pretty common on our cars.
Old 06-24-2010, 09:19 AM
D Griff's Avatar
Originally Posted by RonJ@HT
I would use this method since it is straight from the Honda manual. A piece of hose costs like $0.50, just buy it. Also don't forget to losen the bleed screw, it doesn't mention that. Pretty obvious but it took me a few minutes to figure out back the first time I bled mine.
BrandonClaps
02-19-2020 01:10 PM
RusBear
07-10-2008 11:08 AM
cesar_civic_eg
05-01-2007 03:07 PM
93SiHB
10-02-2005 10:00 AM
Superdragr45
01-26-2004 08:17 PM
Quick Reply: clutch pedal goes to floor and doesn't come back up
