Clutch pedal freeplay changes when driving
94 Civic CX with 1.6 SOHC VTEC
Stock clutch, stock everything.
I notice when I just finish driving on freeways the bite-point on the clutch pedal would change. Instead of biting close to the floor, after freeways, the bite would be further up, and the more freeway I drive the further up it'll get until the clutch feels twice as stiff as original. Does anyone else know what could be my problem? Anyone else experienced this problem before? Thank you.
Re: Clutch pedal freeplay changes when driving
Oh? I tried bleeding it but it'll come back after a while. Could a bad clutch master cylinder cause air to be sucked into the lines?
It sounds like you have a bad master or slave. Check for leaks and replace or you will be stranded soon...
Dude same **** happen to me at the track because i did a wire tuck so now i need to buy a new clutch master cylinder.......but yeah i found out i had an leak in my lines...
I sorta have a similar problem, I'm gonna bleed it and see if it helps..hopefully It doesnt come back like yours did. Might aint too bad though. just feels like I have a lot of free play.
pointblank2305
12-26-2012 05:03 PM
DriveSideWays
08-27-2004 05:06 PM
