clutch need help asap
New User
I just bled my clutch and the clutch pedal doesnt have anything putting it back up so i have to pull it up and i think the clutch isnt engaging in the gears what do i do i need help asap cuz my brother inlaw is coming tomorrow to tow the civic to his shop so im trying to figure out the problem. when i shift the clutch isnt engaging and makes a loud noise like pop cans rattling but once its in gear its fine
I'm not Rick!
Re: clutch need help asap
..sounds like a mess inside the tranny
you have to pull up the pedal with your hand?
you didnt bleed it enough then.
are you positive you put the clutch in right?
You may still have air in the clutch hydraulic system, or the clutch master or slave cylinder is bad. If all of this is good, check whether the clutch fork that contacts the slave cylinder has broken.
New User
hey thanks alot for the help im 16 and tryin to swap a b16 in soon or rebuild d16 and then turbo but ya my brother in law said clutch hydraulic system might be broken eh idk thats for info ill use it when i talk to him.
New User
it just happened yesterday i was driving and the clutch stuck to the floor then it was difficult to get out of 2nd 3rd and 4th gear and 1st to 2nd it jumped like i over reved it and poped the clutch out but i didnt
New User
DenisR
02-19-2016 05:09 PM
KRAP DIVAD
09-04-2005 05:10 PM
gsr camel
09-13-2001 12:05 PM
