Clutch issue
Clutch issue
Sorry for the boring title....anyways when i slip it in first, it makes the car jerk sometimes. Only in first tho. Got a hydro tranny. My bro's all the gears ir u slip it it'll make the car jerk. What gives? oh and when i mean jerk, i just mean the car shakes a lot. Thanks
Mr. Badwrench
Re: Clutch issue (deadend9009)
rest your hand on the pedal, it should move freely about 3/4" to 1" before it starts to build fluid pressure. if it is more than that it will not fully disengage the clutch and you will grind it putting it into gear if it goes in at all. to adjust it, there is a 12mm nut on the clutch linkage at the top of the pedal. loosen it and turn the rod till you have adequate pedal travel. but before you do all that, check it for leaks up by the firewall where the pedal is. look in your reservoir also to see if it is low.
Mr. Badwrench
n.p. i just hope you understand that all. he hee. it is easy if you work on cars but if you dont sometimes it is hard to understand whats goin on.
david236kEG
23
01-28-2009 03:34 PM
