Clutch Fluid leak problem
Old 07-17-2012, 02:49 PM
p3anutboi's Avatar
Icon2 Clutch Fluid leak problem
Below are all the leaks ive found i see there is a leak out of one of the boots by my passenger front tire there is also one from the bottom of the engine where the tranny and engine connect redish in color also a leaking fluid on the down pipe and inside the car by the pedal a really black fluid could any of these leaks be my problem my clutch pedal has been soft lately and i have to refill the clutch fluid resivor every 3 or 4 days my clutch and engine are new i know i have air in the system because while driving the clutch slave i think it is the mushroom bolt popped out and i slid it back in and went on my way so maybe that's my problem? but what about the leaks?
Old 07-19-2012, 10:54 PM
White92eg's Avatar
Default Re: Clutch Fluid leak problem
It looks like your clutch master cylinder may be leaking. This would explain the leak inside the car by the pedals, the reason you have to keep filling up the reservoir, and the clutch pedal being soft sometimes. You can try bleeding the system and adding more fluid for a temporary fix to remove air bubbles. Also, you didn't mention what kind of car you have, but if it is a 92-95 Civic I believe the part number for the master cylinder is 46920-SR3-A01. Buy the one made by Adler. If it is any other car then do some searching to find out. Some of the other leaks look like they could possibly be oil. Clean your motor then trace the leaks to where they start.
Old 07-19-2012, 11:08 PM
Axatax's Avatar
There is almost definitely a leak in the CMC and a replacement (Exedy) runs less than $35.00. You might as well do the slave at the same time and round it out to an even $50.00.
Old 07-19-2012, 11:31 PM
White92eg's Avatar
I would not advocate an aftermarket part in this case, the Adler/Nissin is the OEM version and your best choice, but slightly more expensive. Axatax does make a good point though, you should think about also replacing the slave cylinder.
Old 07-20-2012, 06:08 PM
p3anutboi's Avatar
yea i got the car checked out today the slave is fine the CMC is bad and leaking and my oil pan gasket is leaking on one side tiny leak though ty guys for the suggestions it narrowed it down having it replaced it tomorrow and its 2000 btw :D my bad for leaving that out
eshed
10-18-2013 11:00 PM
tytyguy
12-03-2005 02:32 AM
ej1 coop
02-05-2004 02:08 PM
94dxt
05-08-2003 06:25 PM
PatrickGSR94
12-08-2002 06:36 PM
Quick Reply: Clutch Fluid leak problem
