misfire... / power cut
Old 03-29-2013, 07:42 AM
aceofspades's Avatar
Default misfire... / power cut
So 98 hatch D16Y7 manual 138k
problem she has been having is like 10 to 15 mins into her ride the car will do like half a sec power cut/misfire... I have yet to get it to happen , but now I have codes!
misfire PO300, PO301 , PO303, but tune up is not that old.....
so I need to know Is this a coil Issue or relay some where?
She said when it happens some time the lights cut out also , every now and then it would die but would start right back up no issues
So now i'm left guessing! I don;t just wanna start replacing parts randomly I gotta fix this before I can work on my projects,
any help would be great Ask what ever you want....
Old 03-30-2013, 11:29 PM
Default Re: misfire... / power cut
Any one ?
Old 03-31-2013, 01:44 AM
silkypillows's Avatar
if car shuts off completely when in motion/lights shutting off i would lean towards alternator. if that checks out -
Spark plugs/wires
battery
vacuum leaks - hoses/gaskets (in.manifold/throttle body/etc.)
distributor rotor/coil/ICM
basically in that order - most can be tested/checked easily.
other possibles
main relay
timing / timing belt
head gasket leak
ignition switch
any other codes? any strange exhaust smell/color?
Old 03-31-2013, 06:03 AM
So I gave it a tune up cuz it needed one but after that I got to happen.
All that happened today was driving about. 5-10 into it is I to a light and on take off all I got was a quick half sec check engine light then was fine and kept driving. Didn't feel any thing else so not sure what else it was
Old 03-31-2013, 11:06 AM
92siturbro's Avatar
Try a cooler plug. I had the same issue on my ls/v during normal driving.
RedZoneOS
12-23-2013 12:28 PM
dsnONE
15
04-27-2012 05:39 PM
stiffinEK
01-25-2009 01:08 PM
HBK
12-05-2004 11:33 PM
AzBlackTeg
10-10-2004 05:36 PM
Quick Reply: misfire... / power cut
