Clicking noise coming from the front right?
Well i have some clicking noise coming from the front right it clicks as fast as the wheel is turning but when i press on the brake lightly it goes away? Could my caliper be loose or what is this?
check out the cv joint/boot. if its not that then im not sure what it could be. it might have something to do with the brakes but im not sure what would cause a clicking noise. just get under the car and see if you can notice anything(i.e. open cv boot, inner and outer). oh yeah when you check the cv boot/joints make sure that you check the inner also not just the outer. if the outer is fine and the inner is bad it can still cause a clicking noise. sorry its kinda long but im just tryin to think of somethings it could be
steven
steven
Re: (AeMpwRd eX)
I have the same problem coming from the driver's side. It has been doing it for over a year, and I have no idea what it is. When I try to duplicate it when the car is on a lift I can't. The CV boot is fine.
Re: (young grasshoppa)
A click or a squeak? Mine is a squeak.
I never heard CVs squeak, and I have checked over EVERYTHING down there and can't find it.
I assume my hub is going out or there is a piece of debris in there, I don't know, the squeaking comes and goes but when it is there, goes away with VERY light braking pressure. It's driving me crazy.
Re: (SkyeC)
does it sound like it inside the car....mine comes from inside the car and its on the driver side. I kicked the **** out of my dash one day and it quit. Im not reccomending this but it worked for me.
Re: Clicking noise coming from the front right? (spencedogg)
Turn your wheel to lock on either side and let the car slide forward. If you hear the clicking its a cv joint. I had a rock wedged in the calipers once and it made a clicking noise that changed with wheel speed.
Re: Clicking noise coming from the front right? (fishnfst)
its likely to be your wheel bearing.......jack the side of the car that has the noise.....grab the wheel(one hand on 9 o'clock and the other hand on 3 o'clock)wiggle the wheel....if it moves.....then its a good chance its your bearing.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spencedogg »</TD></TR><TR><TD CLASS="quote">Well i have some clicking noise coming from the front right it clicks as fast as the wheel is turning but when i press on the brake lightly it goes away? Could my caliper be loose or what is this?</TD></TR></TABLE>
Its your cv joints. My civic does the same thing when i turn.
