Tie rod boot ripped off the end
Old 01-11-2023, 01:03 PM
Spaz253's Avatar
Default Tie rod boot ripped off the end
Does it matter if the tie rod boot ripped off from the point where it's sealed?
Old 01-12-2023, 04:30 AM
DaX
DaX's Avatar
Default Re: Tie rod boot ripped off the end
In the long run, yes. It's job is to keep dirt out and grease in. If the boot is ripped, the joint will eventually fail.
Old 01-13-2023, 10:35 PM
Spaz253's Avatar
Ok so can I use a tie rod from a eg or does it have to be from a Integra also because of the b16 motor
Old 01-15-2023, 12:02 PM
Spaz253's Avatar
Here's some pics of the driver side tie rod boot there's still grease in it
Old 01-15-2023, 12:34 PM
Maxcapacity's Avatar
You don't need to replace the tie rod if there's no play in yours just because of the torn boot. If there is play other than it's intended pivot motion then just get a new one and a new boot.
Just replace the torn boot..
Crack the jam nut loose from the outer to inner tie rod, remove the lower ball joint, count how many rotations it takes to unscrew the outer tie rod from the inner tie rod (hold the inner tie rod shaft with a wrench or vise grips because it will spin), remove the torn boot and repack grease to the joint then replace with the new boot and put everything back exactly in reverse so your alignment should be good.
Old 01-15-2023, 12:54 PM
I rebuilt my rack, Here's what it looks like with the boot off, stock tie rod is out.. Replacing the inner tie rods is much easier with the rack out of the car..
Old 01-24-2023, 02:19 PM
Spaz253's Avatar
thanks for ur help I have a question my son wants to know r the tie rod ends supposed move like rotate ? Or they supposed to be stiff and not move at all ?
Old 01-24-2023, 02:26 PM
Spaz253's Avatar
Is it supposed to spin or rotate slowly? When u do it with ur hand?
Bad_dude
03-21-2009 02:44 PM
mxl360
08-22-2007 11:58 AM
snowblind7x
08-15-2006 08:00 AM
Integra Integra
03-22-2006 06:10 PM
SVOboy
11
09-18-2005 05:09 PM
Quick Reply: Tie rod boot ripped off the end
