Civic wont start... has fuel, spark.... help??!! - Honda-Tech
Old 09-08-2010, 10:40 PM   #1
ryan_1014's Avatar
Default Civic wont start... has fuel, spark.... help??!!
Bought a 93 civic lx, bone stock. Had a burnt valve but didnt start when I bought it.
Put a new head on there, timing is dead on, has spark, all injectors are working, fuel pump etc.
no check engine lights, but after trying to start a loud noise is coming from the IACV, im going to try to replace it in the morning but is there anything else that I am missing? All the grounds are good, all 3. all fuses are good. let me know what you think
ryan_1014 is offline   Reply With Quote
Old 09-09-2010, 01:31 AM   #2
ryan_1014's Avatar
Default Re: Civic wont start... has fuel, spark.... help??!!
Bump
Old 09-09-2010, 05:43 AM   #3
Check compression
one6delsol is offline   Reply With Quote
Old 09-09-2010, 06:02 AM   #4
Quote:
Originally Posted by one6delsol View Post
Check compression
^This
And also make sure the plug wires are installed in the correct firing order on the distributor cap.
Former User is offline   Reply With Quote
Old 09-09-2010, 12:51 PM   #5
ryan_1014's Avatar
just did a compression test cylinder 1-4 is (right to left) is 0 40 90 120
the block looked good when I took the head off so im going to recheck timing tonight or maybe the head is warped
Old 09-09-2010, 01:00 PM   #6
ED94LIFE's Avatar
wow dude that sucks
ED94LIFE is offline   Reply With Quote
Old 09-09-2010, 10:09 PM   #7
ryan_1014's Avatar
Quote:
Originally Posted by ED94LIFE View Post
wow dude that sucks
thanks for the feedback stud
Old 09-09-2010, 10:18 PM   #8
phaphon's Avatar
that really sucks did you put the head gasket on correct? if you did a leakdown test you can know whats wrong instead of tearing it down and not knowing where its leaking
phaphon is offline   Reply With Quote
Old 09-10-2010, 10:28 PM   #9
USDM sI's Avatar
the same thing happened to my y8/z6 it was a warped head... and do you know how or why the valve went out?
USDM sI is offline   Reply With Quote
Old 09-10-2010, 11:52 PM   #10
ryan_1014's Avatar
Quote:
no I bought the car like that, the new head i got was supposed to be good so i guess my next step is take the head to a shop and get it machiened and put another head gasket on it
Old 09-11-2010, 11:02 AM   #11
USDM sI's Avatar
well when you pull it i would highly suggest a leak test with water or oil to see if there is possibly bent valves if its warped you would most likely be gettin oil or antifreeze in the combustion chamber or oil in antifreeze or vise versa
95 Civic cranks but won't start moyospeed Honda Civic / Del Sol (1992 - 2000) 11 06-09-2016 05:25 PM
93 accord lx wont start tim73 Honda Accord (1990 - 2002) 6 02-11-2015 03:15 PM
99 civic si won't start... pinoyboy204 Honda Civic / Del Sol (1992 - 2000) 19 03-09-2010 10:47 AM
civic wont start koleslaw Honda CRX / EF Civic (1988 - 1991) 29 12-16-2006 12:47 PM
No spark??? got fuel and air.. flip1199 Honda Civic / Del Sol (1992 - 2000) 3 12-12-2006 01:24 PM
Tags
2001, burnt, civic, fuel, gasket, gettin, head, honda, replace, spark, start, tech, test, valve, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
