Civic won't go faster than 40? - Honda-Tech
Old 09-29-2008, 01:17 AM   #1
hgem1si's Avatar
Default Civic won't go faster than 40?
My friend just bought an automatic civic, he says he cant get it to go over 40 MPH without switching to a lower gear..
I have no idea what to tell him.
Car is a '97 EX
hgem1si is offline   Reply With Quote
Old 09-29-2008, 01:22 AM   #2
hgem1si's Avatar
Default Re: Civic won't go faster than 40? (hgem1si)
bump
Old 09-29-2008, 04:08 AM   #3
Juan_Mitosis's Avatar
Any CEL's?
Ask him more about how the car feels, if it feels different in any way to how it felt before this symptom showed up.
Juan_Mitosis is offline   Reply With Quote
Old 09-29-2008, 04:12 AM   #4
whitemic's Avatar
Default Re: (Juan_Mitosis)
what does limp mode means? would that have something to do with the ecm?
whitemic is offline   Reply With Quote
Old 09-29-2008, 04:24 AM   #5
I changed my mind about limp mode because its very unlikely. But limp mode is this mode your cars' computer enters when something is wrong. It will turn on the check engine light, it will severely retard the engines timing, and lower your rev limiter to somewhere around 3k, 4k ish. Mine has been at 4,200 RPM, and it happened because I had a faulty TPS.
In this persons' case its unlikely because if his car had a lower rev limit, even though limp mode means a huge power loss, the lowered rev limiter would make it almost impossible for downshifting to help gain more mph.
Old 09-29-2008, 11:39 AM   #6
hgem1si's Avatar
Hmm.. Wouldn't this require a CEL though? He just bought the car, he told me that they test drove it around the neighborhood and it seemed fine. Then they drove it home down the freeway and realized they got jooxed.
Any idea what this can mean with no CEL? I'm sure he would have included that in his description to me. We'll see though I'll ask him again later.
Old 09-29-2008, 12:24 PM   #7
Yes, Limp mode is ALWAYS accompanied with a CEL. If the engine continues to accelerate but the car won't pickup speed, something is wrong with the transmission or related components.
If it just won't accelerate, then there is something making that engine loose a lot of power. Maybe its running on three cylinders or so? Spark plug cable problem, severe spark plug problem, distributor problem?
EDIT: Ok just re-read your post, and realized. . . distributor problems would be much more evident in high rpm situations. For example, I'm gonna change my distributor today, its half dead. But if I keep it below 3K RPMS, you would very likely never notice its damaged. But if you jag it a little bit more, then it goes crazy. In my case its the entire distributor gone bad, but once the ROTOR came loose and it was the same symptom, nothing at low rpms, wild bull ride at higher rpms. Good luck!
Modified by Juan_Mitosis at 1:12 PM 9/29/2008
Old 09-29-2008, 12:58 PM   #8
jdm-civicEJ1's Avatar
a woman came into work with an 03 civic coupe dx auto and we scanned the computer and i t through a code imporper gear ratio and they called honda and they sed they were gona do a special tranny flush so iunno ill keep people updated
jdm-civicEJ1 is offline   Reply With Quote
Old 09-29-2008, 01:17 PM   #9
sageuvagony's Avatar
Here's an example of when my car was in limp mode.
I recorded this about a year back.
http://www.youtube.com/watch?v=SCDrlCfFqqI
If you watch further into the video, it's hard for me to even speed up.
sageuvagony is offline   Reply With Quote
Old 09-29-2008, 02:23 PM   #10
Seagull Management
94EG8's Avatar
Default Re: (hgem1si)
Does the CEL come on for a few seconds when you turn the key to on for the bulb check sequence? just wondering if the previous owner pulled the bulb, its not like it hasn't been done before.
94EG8 is online now   Reply With Quote
Old 09-29-2008, 02:29 PM   #11
Default Re: (94EG8)
Quote:
LOL, like many times I'll get into a friend's car and I mention their "check engine light" is on and their same excuse is always "ohh ignore that, the light's broken" and eventually they just pull the bulb.
Wonder if a mechanic has ever done that to a customer, pulling out the bulb and say "ok your car is fixed, no more light, now you owe me $900"
Loud Noise/Thud with 2000 Civic auto trans leeh795 Honda Civic / Del Sol (1992 - 2000) 9 11-14-2009 08:23 PM
07 Civic MPG...... cueto Honda Civic (2006 - 2015) 22 02-06-2009 07:09 PM
FS: 1999 Civic Si stock OEM springs meltman1234 For Sale 6 11-16-2005 05:57 AM
Are 40/40's necessary? 2+2Door Honda Civic / Del Sol (1992 - 2000) 2 03-01-2004 07:07 PM
engine swap info? senbei Honda CRX / EF Civic (1988 - 1991) 3 07-01-2003 08:04 PM
Tags
2001, 40, accelerate, accord, car, civic, crv, del, faster, honda, hour, km, miles, mph, sol, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
