civic rear disk brake help
ok so i have a 92 si oem rear disk brakes i replaced the calipers a few years ago but when i turn the rotor its like the pads are so close to the rotor that it makes noise
also im trying to put the pads back on amd the caliper back on the rotor and the pads are so close together it wont even slide on the rotor am i doing something wrong? the pins are sliding fine
I never narc'd on nobody!
Re: civic rear disk brake help
I'm guessing this is your first time replacing brakes?
Remove the cap from the brake fluid reservoir. Use a large C clamp to compress the brake caliper cylinder. Insert pads into the caliper. Remove the slider pins, re-lube, and re-install. Install the now loaded caliper over the disc, bolt it down to the slider. Reinstall the wheel, take the car off jack stands. Accelerate to 15 MPH, then slam on the brakes (without locking them up) three times. Done.
no one wants to hear the truth
should be stickied
KISS(keep it simple stupid)
brake pad install
Makes compressing the piston so tedious since it keeps slipping off of one side as you turn the wrench
ok so i bought that cube tool and compressed the piston in greased everything (btw the caliper bracket, is that supposed to be able to slide completely off the slider pins?) but now check out this video i can't even turn my hub i dont know whats wrong https://www.facebook.com/photo.php?v...49458765178882
could it be because i havnt driven it yet? i pressed the pedal a bunch of times.. the slider pins are moving good the push in and feel like they want to push out.. the thing that spins im not sure if thats moving at all i mean i used the tool and compressed it in but idk
Oh look, I can change this
Actually, I thought you shouldn't expose the brake fluid to air unnecessarily, as it's hygroscopic and can absorb moisture from the air. But, how long is "too long"?
also check this out https://www.facebook.com/photo.php?v...75428022529767
JDM TypeR 307
02-27-2004 06:07 PM
