civic jack points. - Honda-Tech
civic jack points.
Old 09-23-2004, 08:26 PM   #1
Sport_Injected's Avatar
Default civic jack points.
ok you have the 2 on each side right nest to the side skirts, then you have that off center jackpoint in the front, why did they made if off center? When you jack it up the 1 side is always like 3 inches lower than the other
and is the rear jack point the rear toe hook?
Sport_Injected is offline   Reply With Quote
Old 09-23-2004, 08:30 PM   #2
hayabusa160's Avatar
Default Re: civic jack points. (Sport_Injected)
yep rear jack is the tow hook
hayabusa160 is offline   Reply With Quote
Old 09-23-2004, 08:35 PM   #3
EG_Civic_Si's Avatar
Default Re: civic jack points. (hayabusa160)
there is two up front u can jack up.
EG_Civic_Si is offline   Reply With Quote
Old 09-23-2004, 08:36 PM   #4
HATCHingMN's Avatar
Quote:
Well...If you look under the hood you can see that the motor sits more onto the driverside. So it creat more weight toward the right or driver side!!
HATCHingMN is offline   Reply With Quote
Old 09-23-2004, 08:37 PM   #5
HATCHingMN's Avatar
Default Re: civic jack points. (EG_Civic_GSR)
Quote:
WTF
Old 09-23-2004, 08:45 PM   #6
Default Re: civic jack points. (HATCHingMN)
yea u can jack the car u from the oil pan hahahahah
lmfao!!!!
had no idea theres 2 in front
Old 09-23-2004, 09:07 PM   #7
Downs's Avatar
Quote:
Me either
Downs is offline   Reply With Quote
Official EF/CRX Jacking Points grog Honda CRX / EF Civic (1988 - 1991) 23 02-08-2012 03:49 AM
Jack Points travman Honda Fit 4 04-06-2011 05:55 PM
Rear jack-points are horribly bent and unusuable... ke98248 Honda Civic / Del Sol (1992 - 2000) 9 05-25-2007 08:37 AM
How to Jack a Civic! TurboEM1 Honda Civic / Del Sol (1992 - 2000) 22 03-31-2005 01:20 AM
How do you lift up your car?!?! help now please!!!! variablevalve General Discussion and Debate 28 02-28-2004 11:42 PM
Tags
09, 1992, 2000, 2003, 2004, civic, del, honda, jack, jacking, location, point, points, positions, sol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
