civic hatch wont start, not getting sparks - Honda-Tech
Old 01-18-2011, 02:31 PM   #1
akacoke's Avatar
Default civic hatch wont start, not getting sparks
hi fellas
first off, i pulled fuel line im getting fuel . it will crank but wont start
while i crank it , my dad checked the spark, with 1# cylinder wire, no spark at all.
i replaced the ingnition coil, still not starting and no spark,
im guessinng is the ingnition modual? how do you take it apart? can any one post me a link of a repair manual?
the modual screws is all the way in side the dizzzzy
the car is all stock, never had any issue, besides sometimes when you drive to get gas or to a store, it would start and die. while it dies if you give it gas you will get no reaction, let it chill for a few mins it will start and go. this happens usally after driving it then start it within few mins.
any input would be really appreciated
thanks guys
akacoke is offline   Reply With Quote
Old 01-18-2011, 02:44 PM   #2
Default Re: civic hatch wont start, not getting sparks
Quote:
Originally Posted by akacoke View Post
hi fellas
thanks guys
Have you change the spark plug wire's ?
if not go and buy each plug wire's
and give us an update
Vtecruddy is offline   Reply With Quote
Old 01-18-2011, 11:12 PM   #3
akacoke's Avatar
the wires would be the last thing i would look tho, they could be bad, but in one night and no one touch them? i doubt it
can some one please tell me how to take off the ICM?
there is a aloy plate that covers the screws of ICM, also inorder to take of the aloy plate there is a piece of rubber thing behind the rotor, it gets on the way when i tried to take of the plate to get to the screws
Old 01-18-2011, 11:25 PM   #4
What year/engine?
Have you checked whether the timing belt has snapped or stripped?
Does the Blk/Yel wire inside the distributor get voltage?
Former User is offline   Reply With Quote
Old 01-18-2011, 11:33 PM   #5
akacoke's Avatar
its a 1.5 non vtec, 93 civic hatchback
timing belt is good, cuz when i took off the rotor i had to rotate the motor, so i put it in gear pushed the car, the dizzzy rotor would rotate when i do that. but i will double check of the timing belt snapped
its not the coil for sure, i just put in a new one. how do you take off the ICM?
funny thing is ,i have a multimeter, no one here can teach me how to use a multimeter, i bought a ICM i dont know how to take the old one out
i be working on it first thing in the morning tomorrow, i hope you guys can give me some tips
Old 01-18-2011, 11:37 PM   #6
92-95 Civic with stock D15b7? Realize that a bad igniter unit is but one of several possible causes of no spark.
Does the distributor get voltage?
Old 01-18-2011, 11:47 PM   #7
akacoke's Avatar
i found that first pdf from manual i cant understand how they take off the ICM. is the ICM held by 3 bolts or 2. i bought both of them and a coil
Old 01-19-2011, 10:47 PM   #8
akacoke's Avatar
fixed , new ICM and cleaned IACV
Weird ECU Issue Help Greatly Appreciated ! MugenGuy Tech / Misc 8 04-10-2013 08:42 PM
help please, my car wont start.. im getting fuel and spark.. wanna_run Honda Civic / Del Sol (1992 - 2000) 25 02-07-2012 10:11 AM
1994 Acura Integra LS - Engine Dies, Power Stays On kirkouimet Acura Integra 3 09-04-2011 01:12 AM
Car wont start, please help 94_CRVtec Acura Integra 3 01-06-2005 12:48 PM
How do you relieve a flooded(gas filled) engine? 400whp Acura Integra 5 02-11-2004 02:52 PM
Tags
93, 95, american, civic, cleaned, crank, hatch, hatchback, honda, moduals, motor, spark, start, website, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
