Civic & Del Sol Fuse Panel (printable copies of the fuse diagrams here)
#101
Re: Civic & Del Sol Fuse Panel (printable copies of the fuse diagrams here)
Thank you for this fuse diagram; I'm just getting ready to replace the existing single-cam D16z6 in my 1993 Del Sol with a B16A3 motor and Y21 transmission, and the wiring is the most challenging issue that I'm dealing with.
Is this fuse diagram the same for all three motor options (the D15B7, D16Z6, and B16A3)?
Any help anyone can give me with this swap would be much appreciated.
So far I've learned that the swap requires a different P 54 AC bracket, a different rear engine bracket, a different transmission bracket, axels from a 94 to 2001 Accura Integra, a P30 ECU, different shift linkage, and upper & lower power steering pump brackets.
#104
I just ran across this thread and this image I made a while back. Thought I'd share in case someone else might want this version. It's for the 96-00 Civic, and fits just like the original in the fuse door.
You cut it out and fold it in the middle, so the back has the DTC's (in flash #s) in case you get a CEL somewhere far. You can now use the paperclip/wire trick to pull the code and determine if it's safe to drive or if you want to call a tow truck.
It was a lifesaver for me because it was for my work car that spent all day every day on the raod, and we didn't have smart phones with internet back then.
#106
i have a 97 honda civic dx and I've looked over the fuse diagram am am still stumped about the fuse for the third break light on top of the hatch. can anyone please help.
#107
i can't start my 1994 honda civic, even with new spark plugs
in good condition now
-spark plugs
-engine timing
please help
-spark plugs
-engine timing
please help
#111
I guess the photo's links are broken now... this sticky has become pretty useless in a time of need... I have a 97 civic which has a dash that has been swapped to a 00 and k20 in it.. I'm running into the problem of the ACC option is getting no power.. I'm assuming it contains a fuse in the fuse box but I don't know which one it would be.. some help would be nice
#112
The links work. Click them. They just don't display in the post because imgur doesn't want to be a photo upload service.
Thread locked.
Thread locked.
love my sol
02-21-2012 07:28 AM
Apocolipse269
09-07-2004 07:18 AM
