Civic & Del Sol Fuse Panel (printable copies of the fuse diagrams here) - Honda-Tech
Closed Thread
Old 04-26-2007, 09:55 PM   #1
H-T White Ops
NOFX's Avatar
Default Civic & Del Sol Fuse Panel (printable copies of the fuse diagrams here)
I didn't see this posted anywhere else on here, so I figured I'd post it to help.
I know a lot of people don't have the plastic sheet that fits on the door of the interior fuse panel door. So here is a copy of mine.
Contents:
- 1996-2000 Honda Civic
- 1992-1995 Honda Civic
- 1993-1997 Honda del Sol
Scroll down for others. Titles are in red.
****Special thanks to RARE_EG2 for the underhood diagrams for the del Sol.***
1996 - 2000 Civic
1996 - 2000 Civic * IN CAR * Printable, to keep in your car
1996 - 2000 Civic * IN CAR * Fuse Diagram Explanation
1996 - 2000 Civic * UNDERHOOD * Printable, to keep in your car
COMING SOON!
1996 - 2000 Civic * UNDERHOOD * Fuse Diagram Explanation
1992 - 1995 Civic
1992 - 1995 Civic * IN CAR * Printable, to keep in your car
1992 - 1995 Civic * IN CAR * Fuse Diagram Explanation
1992 - 1995 Civic * UNDERHOOD * Printable, to keep in your car
COMING SOON!
1992 - 1995 Civic * UNDERHOOD * Fuse Diagram Explanation
1993 - 1997 del Sol
1993 - 1997 del Sol * IN CAR * Printable, to keep in your car
1993 - 1997 del Sol * IN CAR * Fuse Diagram Explanation
1993 - 1997 del Sol * UNDERHOOD * Printable, to keep in your car
1993 - 1997 del Sol * UNDERHOOD * Fuse Diagram Explanation
Front
Rear
Ceiling light Trunk Data link connector DLC resistor indicator Auxiliary mirrors Air delivery Blower defogger Fans Compressor Anti-lock brake system ABS Integrated Wiper washer Gauge assembly Roof unlatched indicator system A/T gear position Option connector C B Engine control module ECM Console lights D Stereo radio cassette player Cigarette lighter E Cruise control Vehicle speed sensor VSS SRS unit Charging system not used rear window wiper motor washer motor right Left headlight high beam indicator light power distributor ignition control module front passenger passenger's driver driver's turn signal hazard relay switch PGM-FI main SRS unit VA cruise control system audio unit keyless door lock alternator VSS ELD USA EVAP purge vent shut valve oxygen sensors TCM CVT ABS pump defogger defogger A/C air condition conditioner conditioning option IG2 daytime running Canada low beams VB moonroof relays relay gauge and indicator interlock windshield wiper windshield washer integrated accessory socket ACC audio dash ECM PCM PGM-FI front parking taillights license plate key solenoid fuse panel diagram map 1996 1997 1998 1999 2000 96 97 98 99 00 '96 '97 '98 '99 '00 coupe hatch sedan inter lock interlock unit h/l low high beam p/w power window windows dr door doors lock locks as license tail lights taillights starter signal running ig coil ignition instrument back up back-up backup rr-r rr-l radio clock heater a/c relay security cigarette lighter acc accessory socket rr def relay fr wiper washer alternator sp sensor meter cruise control fuel pump srs turn amperage amp fuse box diagram
Last edited by Former User; 08-25-2012 at 07:11 AM. Reason: Added 92-95 Civic hood fuse box information
NOFX is offline
Old 04-28-2007, 02:23 AM   #2
VRD^don's Avatar
Default Re: (NOFX)
THANK U..i've been loooking for this for a long long time..!
VRD^don is offline
Old 04-28-2007, 05:27 AM   #3
DXBSOL's Avatar
i wans searching for full electrical diagram for my 96 delsol if you can send it to me it will be a great help from you
DXBSOL is offline
Old 04-28-2007, 11:59 AM   #4
H-T White Ops
NOFX's Avatar
Default Re: (DXBSOL)
Quote:
That would be so so much work to put it all together. I have the wiring diagrams for the '97 del Sol (don't ask me where I got them from, I find stuff and I save it because it might be useful in the future). I've had it for over two years and it comes to 40 pages. There's no way I could send it to you and no way in hell I'm going to try to post it all up here anyway.
Anyway, this thread is for the fuse panels on the cars, not for wiring diagrams. Sorry.
NOFX is offline
Old 04-28-2007, 01:19 PM   #5
jmark's Avatar
Default Re: '96-'00 Civic Fuse Panel (NOFX)
jmark is offline
Old 04-28-2007, 07:15 PM   #6
zerovandez's Avatar
Sticky!
zerovandez is offline
Old 04-29-2007, 02:07 AM   #7
DXBSOL's Avatar
Default Re: (NOFX)
it's ok man if you cant Post It .
what about the fuses box's of 96 Del sol ; do you have them or no if yes just tell me i will give you some space on my server so you can save the file on it through FTP.
DXBSOL is offline
Old 04-29-2007, 02:53 AM   #8
H-T White Ops
NOFX's Avatar
It took some searching. But I found it.
Look in the first post for it.
Modified by NOFX at 3:32 AM 4/29/2007
NOFX is offline
Old 04-29-2007, 04:43 AM   #9
DXBSOL's Avatar
Default Re: (NOFX)
Thank you For the diagram
DXBSOL is offline
Old 05-01-2007, 08:20 PM   #10
winneth's Avatar
thanks for posting this,
I was looking at the fuse diagram for the 96-00 honda civic and i see the fuse related to c927[option dash lghts], c928 [ (ACC) ] and c929 [option IG2] but i dont see the fuse for c926 option +B
Does that mean thres no fuse for that?
winneth is offline
Old 05-01-2007, 08:26 PM   #11
uneek360's Avatar
damnit i was looking for this.... is it in the FAQ area ?? I didn't see it...
uneek360 is offline
Old 05-01-2007, 09:29 PM   #12
winneth's Avatar
Default Re: (uneek360)
Honda-Tech.com Honda Civic/Del Sol (1992 - 2000) Civic & Del Sol Fuse Panel (printable copies of the fuse diagrams here)
winneth is offline
Old 05-01-2007, 10:14 PM   #13
uneek360's Avatar
Default Re: (winneth)
Quote:
wtf ??
uneek360 is offline
Old 05-01-2007, 11:55 PM   #14
H-T White Ops
NOFX's Avatar
Look in the diagram and you'll see above the squares spaces with tiny circles in them. Those circles each are numbered. Number 1 is right above fuse 25 and is for C926.
Quote:
Yes, it is in the FAQ as "'96-'00 Interior Fuses".
I asked a mod to change it, but I asked for other things at the same time and it must have been confusing.
NOFX is offline
Old 05-02-2007, 02:48 AM   #15
H-T White Ops
NOFX's Avatar
Updated.
NOFX is offline
Old 05-02-2007, 03:00 AM   #16
BlueIntegraBoy's Avatar
Default Re: (NOFX)
Good stuff
BlueIntegraBoy is offline
Old 05-02-2007, 04:33 AM   #17
winneth's Avatar
Default Re: (NOFX)
Quote:
Im a bit confused at what you're saying. I see that number 1 is above fuse 25 but that square with the circle number 1 is not a fuse. I was asking if there was a fuse for it.
Here is what i see so far...
C927 Dash light --> has Fuse 30
C928 ACC --> has Fuse 28
C929 IG2 --> has Fuse 17
C926 Option B+ --> has Fuse ????
Similiar to the other models, all the option connectors b-e have fuses but none of the option a's do...
winneth is offline
Old 05-02-2007, 05:20 AM   #18
Thanks alot great info.
FFEG6 is offline
Old 05-12-2007, 06:02 PM   #19
Ohmster's Avatar
Default Re: '96-'00 Civic Fuse Panel (jmark)
Dude, I need to find a bad connection between my radio and cigarette lighter. Pushing in the lighter will often black out the Blaupunkt stereo and the lighter, either remove the lighter to sometimes restore it or shut the car off for a few minutes to get the radio working again.
I own a 1995 Honda Civic Del Sol
Worse, all electrical features on the steering wheel itself do not work. No SRS light on the dash, ever, not even when turning on the ignition, no horn, and no cruise control. I am an electronic tech of 30 years and could track down these problems with an accurate wiring diagram, including wire colors, all plugs, and pin assignments on the plugs. Probably a bad reel cable (clock spring) but that is an expensive part and I cannot afford to buy it unless I am absolutely sure that it is what I need as electrical parts are rarely, if ever, returnable.
I find stuff too, all over the Internet, but am having trouble with finding complete wiring diagrams for automobiles. Could you please offer some advice on how to find such things, private message is okay as sometimes "we gotta do what we gotta do"?
With such a diagram, I could find the correct plug to the problem area and use my DMM to troubleshoot by looking for shorts, making sure of connections, and finding open circuits. I even have a signal tracer where you can put a signal on any wire and the other part is a very sensitive microphone that will allow you to zero in on the other end of the cable and locate it quickly.
Please, any help or advice would be greatly appreciated. Have private server for any software or digital exchange that might be necessary. I could fill some of your requests if you have any. Thanks.
Ohmster is offline
Old 05-12-2007, 06:45 PM   #20
94hatchling's Avatar
fantastic. i lost mine long ago.
can someone make sure this is put in the FAQs Thread? its most beneficial.
mad props to the OP!!!
94hatchling is offline
Old 05-12-2007, 11:10 PM   #21
H-T White Ops
NOFX's Avatar
Default Re: '96-'00 Civic Fuse Panel (Ohmster)
I said what you quoted, not jmark.
Also, I think since you're currently still a trial member that you can't send or receive private messages here. So you'll have to wait a little longer to IM me here. Sorry.
If you had a visible e-mail address or instant messager listed in your profile then I'd try to help you, but it looks like your email is hidden and you have no messager listed. Once you are no longer a trial member I'd be happy to try to help you out.
I just save what I find. Whenever I find something useful, I save it. It doesn't have to be something useful to me right now for me to want to save it. That way, two years later when I might need it, I have it.
So there really isn't a special method to finding this stuff besides lots of searches, reading stickies and FAQs on all sorts of Honda sites and just some luck of stumbling upon some good sites.
It's already in the FAQ.
Glad it's helping.
NOFX is offline
Old 05-15-2007, 08:21 PM   #22
sario's Avatar
useful for everday troubleshooting
sario is offline
Old 05-15-2007, 08:59 PM   #23
lamboextreme's Avatar
Default Re: '96-'00 Civic Fuse Panel (sario)
lamboextreme is offline
Old 06-08-2007, 08:31 PM   #24
hybridclassic626's Avatar
Default Re: '96-'00 Civic Fuse Panel (lamboextreme)
love this I saved the pics to my phone
hybridclassic626 is offline
Old 06-12-2007, 10:00 AM   #25
tryin2ride's Avatar
Default Re: '96-'00 Civic Fuse Panel (hybridclassic626)
this helps a lot when your missing your fuse box cover. thanks
tryin2ride is offline
Closed Thread
HELP! I need a Diagram of the 94+ GSR Fuse Box(underhood)!!!!!!!!!!!!!!!!!! intekragsr Acura Integra 18 04-20-2016 07:52 PM
[DIY] Honda Civic 92-95 EDM Heated Seats DIY Retrofit Install Guide deschlong Honda Civic / Del Sol (1992 - 2000) 60 01-12-2016 02:23 AM
Honda Civic 96 1.4i sedan clock and car stereo Pliskins Honda Civic / Del Sol (1992 - 2000) 5 12-21-2015 02:49 PM
NJ 1997 Honda Civic EX JDM B18C with 5 speed LS - $4500 OBO Thor294 Vehicles for sale 47 02-10-2015 05:46 AM
***DC HEADERS**** CLEARANCE SALE!! $245-UP!!! CHEKC IT OUT! myeXtremeparts Performance 64 01-27-2012 04:36 PM
Tags
1993, 1998, 93, 98, box, civic, del, diagram, fuse, honda, locations, panel, sol, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
