Civic Dash Lights!!!!
Old 05-13-2005, 08:35 AM
Vtec77's Avatar
Default Civic Dash Lights!!!!
My dash lights on my instrument panel went out. So now i dont have a light for my speedometer, gas gauge, temp gauge, but all the other warning lights work. I tried checking to see if the dimmer switch was broken i dont think it is. Everytime i put in a new fuse into the #30 slot for the lights it blows no matter what. I took the dimmer switch out and it still blew. I took apart the dash and took out instrument cluster followed the wires to see if there is a short anywhere but i couldnt find one. got any ideas? please help
Old 05-13-2005, 08:38 AM
duggy's Avatar
did you check your radio for a short? i know i had a short in the radio and it blew the radio fuse and the cluster fuse. do you have lights in the back at night?
Old 05-13-2005, 12:36 PM
silvergo's Avatar
Default Re: Civic Dash Lights!!!! (Vtec77)
i'm having a similar problem, my dash lights occasionally black out and the emergency break light goes on. headlights and tail lights continue working fine. checked wiring, but couldn't find anything faulty. let me know if you have any luck...
Old 05-13-2005, 02:58 PM
Elson23's Avatar
im having the same problem with my CTR cluster in my 96 CX.... if u find out any info let us know please...
Old 05-27-2005, 04:15 AM
jcmurp's Avatar
Default Re: (Elson23)
You may need to check the drivers side multiplex. it is located on the drivers side fuse panel,it is the blue box. I had the problem and turned out that it was the multiplex. It happens allot if you replace the factory stereo.
Old 05-27-2005, 04:41 AM
I am a (Trial User) Army
litterbox's Avatar
Default Re: Civic Dash Lights!!!! (silvergo)
If your dash lights are flickering on and off periodically it's your dimmer switch.
Old 05-27-2005, 06:48 AM
Crasian's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">did you check your radio for a short? i know i had a short in the radio and it blew the radio fuse and the cluster fuse. do you have lights in the back at night?</TD></TR></TABLE>
this happened to me the other day, i wasted a 2 good fuzes too :@
Old 05-27-2005, 07:29 AM
litterbox's Avatar
Default Re: (FarOutCoupe)
Just check fuse 15 and the backup fuse in the engine bay, but if the lights are flickering it's the dimmer switch.
shoebox
09-28-2012 04:39 AM
slob20ef
03-30-2009 05:43 PM
hYbRiD EeEkAy
13
07-16-2004 02:57 PM
Quick Reply: Civic Dash Lights!!!!
