Civic clicks when trying to start,whats wrong? - Honda-Tech
Old 03-20-2011, 06:19 PM   #1
Default Civic clicks when trying to start,whats wrong?
When i turn the key all i get is a click sound watch the video below you can hear the clicks every time the key is turned.
[youtube]6WnlR33JCvk[/youtube]
xjm92x is offline   Reply With Quote
Old 03-20-2011, 06:22 PM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: Civic clicks when trying to start,whats wrong?
Stupid question. Is the battery charged?
grumblemarc is offline   Reply With Quote
Old 03-20-2011, 06:24 PM   #3
yeah, all the lights turned on, the radio and i used it 2 hours before this started happening and everything was fine
Old 03-20-2011, 06:26 PM   #4
The Grumpiest
How old is the battery? Can you jump start it?
Old 03-20-2011, 06:34 PM   #5
mavvrik's Avatar
Do you have a security system on it. It happens a lot when you have an aftermarket alarms. Check the voltage on the battery, and see what the voltage drops too when you try to start it.
My accord use to do it all the time in cold weather. I had corrosion on my battery cables and it would cause the Security system to trip out because the corroded cables were causing resistance in the wires
mavvrik is offline   Reply With Quote
Old 03-20-2011, 10:02 PM   #6
harmonator84's Avatar
It's battery. Have it checked at advance or autozone.
harmonator84 is offline   Reply With Quote
Old 03-20-2011, 10:07 PM   #7
DOHC_Hatcher's Avatar
if said battery is good check for voltage at the signal wire on the starter solenoid
DOHC_Hatcher is offline   Reply With Quote
Old 03-21-2011, 06:00 AM   #8
either your battery is dead, your starter is bad, or both.
300whpej is offline   Reply With Quote
Old 03-21-2011, 08:15 AM   #9
ekVic214's Avatar
id say check the starter. can u pop the clutch and turn the car on like that?
ekVic214 is offline   Reply With Quote
Old 03-21-2011, 09:01 AM   #10
IhateworkingoncaRs's Avatar
From the sound of it, that's a bad starter.
IhateworkingoncaRs is offline   Reply With Quote
Old 03-21-2011, 09:05 AM   #11
alphalanos's Avatar
double check the terminals and cables, make sure its all clean and tight. have someone tap on the starter while you hold the key in the start position. If that doesnt work, try putting a rubber or plastic handle screwdriver across the starter posts on the side while someone holds the key in start position.
Also check your clutch pedal to see if the plastic thing is missing where it hits the switch.
alphalanos is offline   Reply With Quote
Old 03-21-2011, 09:12 AM   #12
Thats either a bad connection on the battery or more likly a locked starter. If the battery was dead it would click multiple times like a empy mag on a automatic rifle lol. Thats the best way to discribe it. Try push starting it, have it in second gear and have someone push the car then have the key turned to the on II position and pop the clutch.
NOYGDB is offline   Reply With Quote
Old 03-21-2011, 09:14 AM   #13
To the best of my knowledge it couldent be a bad saftey switch of a starter relay because you wouldent hear them click like that if they were bad. They wouldent make any noise at all.
Old 03-21-2011, 09:14 AM   #14
S2Integra's Avatar
clicks always indicates starter solenoid is not actuating, so if battery is charged, the starter is bad. Maybe a loose wire. But everyone here has said this already
S2Integra is offline   Reply With Quote
Old 03-21-2011, 12:36 PM   #15
i have a 96 civic with what seems to be a alarm that is disconected minus a switch that i have to push to turn the car on, problem my car won't turn on any more i put a new battery starter is good. it doesn't even turn over. i have to push start it to get it on(manual transmission). any ideas anyone?
bigdough281 is offline   Reply With Quote
Old 03-21-2011, 07:07 PM   #16
mavvrik's Avatar
^^^My first idea would be to start your own thread home slice.
Old 03-22-2011, 03:58 PM   #17
ekVic214's Avatar
Quote:
x2
turn signal relay clicking jooky5 Honda Civic / Del Sol (1992 - 2000) 8 04-23-2013 12:59 PM
click click click click spacin Honda Accord (1990 - 2002) 10 12-28-2007 06:33 AM
turn over but no start d15bdelsol Honda Civic / Del Sol (1992 - 2000) 5 08-09-2007 12:13 PM
Car clicking fast and light dims when starting hatching Honda Civic / Del Sol (1992 - 2000) 3 07-31-2007 12:05 PM
Click...Click...Click...car wont' start Ph0eNix Acura Integra Type-R 20 12-15-2005 12:58 PM
Tags
07, 2002, automatic, car, civic, click, clicking, clicks, gun, hear, honda, sounds, start, whats, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
