Civic 99-00 DX hatchback - How remove license plate light covers to change the bulbs? - Honda-Tech
Old 11-01-2010, 06:38 PM   #1
Team_Insane's Avatar
Default Civic 99-00 DX hatchback - How remove license plate light covers to change the bulbs?
So I own a 2000 Honda civic DX Hatchback and I'm wanting to clean the reat license plate light covers and swap out the bulbs, but I can't get them to come off. Any help on how to remove it would be nice thanks!
Team_Insane is offline   Reply With Quote
Old 11-02-2010, 12:25 AM   #2
Default Re: Need help! Civic 99-00 DX hatchback
39 views and nothing? bump!
Old 11-02-2010, 01:20 AM   #3
H-T White Ops
NOFX's Avatar
I remembered removing the license plate lights on a '97 CX hatch, but those were just held in by two Phillips screws, so I figured you couldn't have overlooked that.
But I knew that in 1998 Honda added a lift handle to the rear, right above the license plate. So that could very well have changed the design of the license plate lights.
So I checked on HondaPartsDeals.com for a pic and what do you know, there it is.
Here's the little image I made from their pic to better explain.
Looks like the '96-'97 hatches have license plate lights held in with two Phillips screws, but the '98-'00 hatches have some sort of clip in license plate light assembly.
I'm not sure how hard they'll be to remove, but I'd imagine this means they can be pried out.
NOFX is offline   Reply With Quote
Old 11-02-2010, 07:36 AM   #4
damien1023's Avatar
I'm pretty sure when I did this to clean the lens on mine I just used a flat head screw driver and pried the side off. I believe it was held in by clips so just be careful and take your time.
damien1023 is offline   Reply With Quote
Old 11-02-2010, 11:54 AM   #5
D50boy's Avatar
Default Re: Civic 99-00 DX hatchback - How remove license plate light covers to change the bu
There should be a tab that you will have to move to unhook it in order to pull it out. It breaks easily so be careful. I found that out the hard way. I need a new one.
D50boy is offline   Reply With Quote
Old 11-04-2010, 08:04 PM   #6
Thanks guys!
92-95 License Plate Light Bulbs Dekorum Honda Civic / Del Sol (1992 - 2000) 7 01-02-2014 08:04 AM
license plate lights?? Luke G. Lighting 4 01-04-2009 02:01 PM
License plate light chris92089 Acura RSX DC5 & Honda Civic EP3 5 09-21-2007 08:55 PM
how to remove the license plate bulb cover to change bulbs out 949 Honda Accord (1990 - 2002) 2 08-12-2007 09:31 PM
!HELP! LICENSE PLATE LIGHTS honda2151 Honda Civic / Del Sol (1992 - 2000) 9 01-27-2007 04:17 PM
Tags
00, 2000, 98, 9900, bolt, civic, cover, hatch, honda, license, light, lights, plate, removal, tag
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
