Civic 93 will not start. Cranks up, but will not start? No spark - Honda-Tech
Old 12-02-2011, 04:42 PM   #1
Default Civic 93 will not start. Cranks up, but will not start? No spark
Honda Civic 1993 will make the starting sound(starter motor cranking up), but will not start the engine.
My mate, pulled out one of the sparkplugs holder and tried to see if any electricity will spark when touching the engine as I try to start it but nothing.
Is there a test procedure I can do, to find out what the issue is?
I am thinking it could be the distributor, but that would just be guessing.
honvic is offline   Reply With Quote
Old 12-02-2011, 06:13 PM   #2
Texas4door's Avatar
Default Re: Civic 93 will not start. Cranks up, but will not start?
If you have no spark....it's the ignition coil located inside the distributor!
(or the distributor/rotor in the distributor cap itself is toast)
Ignition coil is kinda pricey, but the cap/rotor is cheapish
Do all three and rest easy!
Good luck!
PS: wires too just in case they're old and rickety and not transferring spark.
Texas4door is offline   Reply With Quote
Old 12-02-2011, 08:04 PM   #3
I got a EG8 with a D15b and I had a problem where I was figuring out how to get my car started. I first changed the plugs and wires. Nothing. Changed the fuel pump. Nothing. Cap and rotor did nothing as well. I cleaned the engine with seafoam thinking there is sludge clogging the engine. Nothing after that. I then changed the Coil as Texas4door says. It works! Advance auto parts has the coil for 50 while autozone and o'reilly have it for 80... Advance's one comes with lifetime as well.
Simplypinoy is offline   Reply With Quote
Old 12-03-2011, 08:21 PM   #4
is the battery fully charged
s14-13b is offline   Reply With Quote
Old 12-03-2011, 08:55 PM   #5
Texas4door's Avatar
Quote:
It sounds like it is, otherwise his starter wouldn't be cranking...
Having any luck, OP?
Old 12-04-2011, 01:46 AM   #6
Marvin1985's Avatar
Change the ignition cap and rotor 1st then look at wires/plugs cuz if the cap and rotor are bad most likely it needs a tune up anyway
Marvin1985 is offline   Reply With Quote
Old 12-04-2011, 02:17 AM   #7
tjdmcoupe's Avatar
Try checking your main ignition relay. Its located under the dash on the drivers side. To the left of the fuse box.
-hold your hand on the relay then turn the car to the on position, the relay should click once when turned to on position then again after correct fuel pressure is established.
(Check engine light turns off at the same time of second click)
- these relays are a very common problem for civic 88-95. Come across it more than 6 times
- they control the fuel and ignition.
tjdmcoupe is offline   Reply With Quote
Old 12-04-2011, 08:27 AM   #8
honvic --> tell us whether or not the fuel pump primes and whether any CEL codes are thrown.
Former User is offline   Reply With Quote
Crank crank crank Xavier Mckinney Hybrid / Engine Swaps 4 05-04-2016 05:02 AM
H23vtec won't crank dashocker Honda Prelude 7 09-01-2008 04:26 PM
spark issues britanns Honda Civic / Del Sol (1992 - 2000) 1 12-12-2007 06:17 PM
high compression engine wont start civic_driver_389 Acura Integra 2 05-19-2007 04:11 PM
Only starts sometimes. (need opinions) DeadVet Tech / Misc 20 08-10-2005 08:50 PM
Tags
1993, 93, cap, changed, civic, crank, ef, honda, ignition, ignitor, relay, rotor, spark, start, tech, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
