Check Engine Light GO AWAY!!
Old 09-01-2010, 09:52 AM
Bakuryu06's Avatar
Default Check Engine Light GO AWAY!!
Hey guys, got a new 95 Civic DX. Check engine light was showing. Changed O2 sensor and it went away. Now, when i drive the car, the car hiccups as if there is no gas and then almost turns off but doesn't and the check engine light comes on. Its an OBD1 ecu so can't test the jumpers with a scanner.
I know u can use a pin to jump the ECU cable to get a blinking code. However, the check engine light turns off when the car is turned off and stays off when turned on until the HICCUPS. Is it safe to jump the PIN while the car is running???
Old 09-01-2010, 09:57 AM
EJeff8's Avatar
Default Re: Check Engine Light GO AWAY!!
^Yes. If you read the CEL thread it states this for OBD1 ecus.
OMGBBQTEHWTFDOOD
10-19-2007 10:18 AM
89civichb
05-10-2007 06:42 PM
jamzm101
04-02-2007 12:00 PM
98teg
10-06-2003 07:39 PM
VTECVillain
01-06-2002 11:40 AM
Quick Reply: Check Engine Light GO AWAY!!
