Check engine light, ECU Code P1457
Old 12-07-2005, 02:27 PM
jeremy8886's Avatar
Default Check engine light, ECU Code P1457
A while ago I had my check engine light come on, and after going to the dealer ship and replacing a two way valve or something, then having another mechanic reset the code and tell me that it was due to me parking on hot pavement and evaporating or something. I don't know... So I purchasing a used OBD reader it came up with the code P1457, which is - "EVAP emmisions Control System Leak Detected (Control Canister System). Does anyone know where I can start or what I should do to solve the problem. Thanks for any help in advance.
Old 12-07-2005, 03:07 PM
Chiovnidca's Avatar
Default Re: Check engine light, ECU Code P1457 (jeremy8886)
Year and model? Some of em have known problems.
Old 12-07-2005, 06:45 PM
jeremy8886's Avatar
Default Re: Check engine light, ECU Code P1457 (Chiovnidca)
2000 Honda Civic Si (Canadian)
Old 12-07-2005, 06:54 PM
Stripped Honda's Avatar
it could be the purge valve on the canister, the gas cap bad or not tight or the fuel tank not sealed properly ... this can be a really tough thing to check if you dont have the proper tools
h22egAZ
04-28-2009 08:55 PM
1998_4dr_gsr
01-24-2006 05:03 PM
trw6730
07-14-2004 10:10 AM
2camsaam
10-18-2003 09:43 PM
CRX2NV
04-29-2003 11:40 AM
Quick Reply: Check engine light, ECU Code P1457
