check engine light
Re: (krazyhmongboi)
I already replaced the sensor under the hood in the exhaust manifold and tried clearing the code but it came right back on. any suggestions would help
Re: (PACMAN8)
so do u think if I go with a denso o2 sensor the code should clear? What about changing the o2 sensor in the cat would that help at all.
Re: (bma1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bma1818 »</TD></TR><TR><TD CLASS="quote">so do u think if I go with a denso o2 sensor the code should clear? What about changing the o2 sensor in the cat would that help at all.</TD></TR></TABLE>
No, it won't clear.
Yeah it's true that Denso's are good, but a new O2 sensor for your car is a new O2 sensor for your car. You shouldn't still be throwing the light.
EDIT:
Changing the cat O2 sensor won't do anything - it's a primary O2 sensor code.
No, it won't clear.
EDIT:
Re: (Syndacate)
This all started when I took off my stock catalytic converter off and put a ebay hi-flow one on. As soon as I did that my check engine light came on. So I replaced the o2 sensor in the exhaust manifold with a bosch one and tried to clear the code, but the light came right back on. Any Ideas would help
Re: (tha_badguy)
Well I ended up putting the stock cat back on because I thought it was causing the problem and I still have the cel on. Is it worth getting a new 02 sensor?
crxtreme27
09-19-2002 02:01 PM
