changing valve cover gasket
Old 04-15-2014, 06:31 PM
LandeZak's Avatar
Default changing valve cover gasket
I bought a new valve cover and gasket for my car. I am just wondering the tools I need and if I need to apply sealant? And if I do what are some good brands to buy for the sealant. Thanks!
Old 04-15-2014, 06:32 PM
Fliptard's Avatar
Default Re: changing valve cover gasket
if you are using OEM seals, you don't need any sealant. And as far as tools, a 10mm socket, racket and... that's about it. If you torque the nuts correctly, it the right order, it shouldn't leak.
Old 04-15-2014, 06:34 PM
LandeZak's Avatar
ok thank you
Old 04-15-2014, 06:42 PM
LandeZak's Avatar
Anything specific I should look out for I might break?
Old 04-15-2014, 08:11 PM
Hysterically Calm
TomCat39's Avatar
Which series of car? 92-95 or 96-00?
Ether way, fliptard is incorrect, Hondabond is recommended in the 90 degree angles of the gasket typically so 4 points on the gasket, 2 on the timing belt side and 2 points on the distributor side. Permatex "The Right Stuff" grey is the same thing as Hond Bond and is cheaper per oz than Honda Bond.
Below is the FSM page for the 92-95 series for the D16Z6 but is the same valve cover torque spec of 7 ft-lbs and the same points for Hondabond for all 92-95 motors, I believe the 96-00 is pretty much the same as for where to put the Honda Bond:
Old 04-15-2014, 09:22 PM
Stancetard Hate Monger
eghatch9295's Avatar
i know the fsm calls for it, but on my MANY honda/acura products, ive never used it.
Old 04-15-2014, 11:11 PM
PrettyMuchBoned's Avatar
IV been told to use automotive silicone before, mostly in the corners, and lightly brushed around the whole thing.
absolutely make sure not to over tighten the nuts, or they will become useless.
Old 04-15-2014, 11:25 PM
i honestly think it calls for sealant because the gaskets love shifting around/falling off when you flip the cover over to reinstall it. can be a pita.
Old 04-17-2014, 03:47 PM
LandeZak's Avatar
ok thank you. this helps a lot
Old 04-17-2014, 04:34 PM
Technical Hero
HondaPartsHero's Avatar
http://www.d-series.org/forums/diy-f...w-gaskets.html
caliskier
03-22-2009 04:45 PM
miksew
13
10-20-2006 05:48 PM
snouka
03-26-2006 10:05 AM
darkfx
10-08-2005 09:51 AM
JBBNJ609
09-21-2003 09:16 PM
Quick Reply: changing valve cover gasket
